Question about Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Ultra Wash 665.1374 not draining
We just remodeled our kitchen and moved the dishwasher. We followed the instruction manual exactly, but the first time we ran it we stupidly forgot to turn on the water supply valve. Duh! It went through a complete cycle. After that, it seems to work fine, except that it doesn't completely drain all the water. If I press the "cancel drain" button 3 times, the dishwasher empties. The knock-out plug is out and I've tried to reposition the drain hose, which seemed to help a little. Are these two things related or is it not draining because of something else? Many, many thanks in advance.
Posted by mom4429 on
  • mom4429 Jul 10, 2009
    Nevermind... we figured it out. We just had to recalibrate the wash cycle since the first wash had no water. It's working fine now. Thanks anyway!
5 Related Answers
SOURCE: Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Posted on Nov 05, 2008
Anonymous
  • 338 Answers
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Posted on Nov 25, 2008
Anonymous
  • 338 Answers
SOURCE: I have a Sears Kenmore
call sears service and tell them you need service there is a service flash and will be no charge
Posted on Dec 23, 2008
Anonymous
  • 338 Answers
SOURCE: I have a Kenmore Ultra Wash Portable dishwasher
most are you shouldonly have to take the kit off of it that makes it portable.. however it is very difficult
Posted on Aug 29, 2009
Anonymous
  • 127 Answers
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Posted on Oct 25, 2009
I have a Kenmore Elite Ultra Wash Dishwasher 665.1319 and it won't get rid of the water it used completely
check the positioning of the waste water hose from the pump
it could be kinked from the re-installation, too high to drain or other re-modelling problems
Sep 04, 2015 | Kenmore Dishwashers
Kenmore ultra wash dishwasher won't drain tried
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 27, 2010 | Kenmore 16764 Dishwasher
I have a Kenmore Ultra Wash Portable dishwasher Model 665.1776. Was wondering if this was convertable to a built in as I am remodeling the kitchen
Aug 29, 2009 | Dishwashers
Kenmore Ultra Wash III Dishwasher will not drain properly
Fixerfailure, is the knock-out plug still inside if the garbage disposal inlet?
Stick a screwdriver in there to make sure.
spazmo1969, could be the rubber flapper is broken off in the pump discharge outlet.
Dec 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
From the sound of things, your dishwasher drains faster than your sink drain ( via the garbage disposal) can drain it off.. You may have a problem with the way your sink drain/trap is vented and there is too much back pressure to drain down quickly.. When you run water from your sink, does it take a long time to drain down or if you fill your sink up and drain it, does it drain slowly ? That may be your problem.. Hope that helps.
Aug 26, 2008 | Dishwashers
Kenmore ultra wash dishwasher model665
You have a restricted drain in your sink, not the dishwasher. Water is unable to go down drain fast enough and is backing up.
Nov 13, 2007 | Dishwashers
Kenmore 24 in. 15689 Built-in Dishwasher Logo
300 people viewed this question
Top Kenmore Dishwashers Experts
gbob59
Marvin
Marvin
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
