power will not come on
Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Samsung TV won turn on blinking red light explained fix 18
My TV surname off after 5-15 minutes of use. The red light in the front blinks once every 3 seconds continuously. If I hold the power button down on the tv, it will turn on and do the same thing.
hi,
In your tv there some problem with power supply. you have to check the followin voltages. Sub 5v SOS ,Main 3.3v SOS A-Board,DTV 9v SOS , Tuner Power SOS. If any one of the voltage fails it will shows 10 blinks.
ok
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
