Question about Toys
Disassembly of Little Tikes Wave Slide playground
Need to disassemble this. Any ideas?
Here is the product...
http://www.littletikes.com/toys/wave-climber.aspx
Has instruction manual, but not disassembly. Need tips on how to separate the pieces. They fit together like a puzzle.
Posted by jorgfamily on
Anonymous
The key is that one side/side combination must be done 1st then the others are easy. On ours I think it is the yellow/orange combination. Just try all the combinations. One works pretty easily, the others do not. We struggles too until we found the right combination. good lluck
Posted on Aug 15, 2009
  • Anonymous Jan 08, 2011
    To assembly or disassembly the key definitely with the YELLOW and ORANGE combination join area.
    To assembly, join all the wall panels (Green
Anonymous
Hi there! On putting together my daughter's hide and slide (not having ordered it or seen it before) followed the instructions and managed to put the bottom step inside the frame instead of outside. Of course other half only noticed it once I had put the top step in - so to take it apart you will need the following:
Two long heavy duty flat bladed screw drivers and a lot of muscle!
First take the top platform on one side and disengage the two tabs on one side. Then insert one of the srewdrivers under the red locking tab and push up - the plastic will distort however, returns to original shape with judicious use of a heavy hammer. You will need to use the second screwdriver to disengage the clip in the tab and then twist the platform out of the frame to release the second. Repeat for the other side. The bottom platform is a just a reversal of the installation to release. I haven't moved the slide but as this is a 'gravity' fix should release with a bit of 'persuasion'. As these things are not designed to be taken apart after assembly they are frustrating to take apart - but with a little flex and muscle it can be done. Hope this helps.
Simon
Posted on Aug 02, 2009
bernice chau
    New Friend:
If it is a an old triangle climber, one side comes off easier than the others. For us, it was the yellow/orange side. Tip the climber on to the side and slide/shimmy it off. This may not be the easy side for you but once you get one side off, the other 2 will be easy. No tools needed. (Before finding this tip online, we tried hammering it and prying it and just applying brute force to no avail! Once reading this, it was easy!)
Posted on Apr 08, 2016
I need a new steering wheel for a little tykes cozy coupe can you help please?
Little Tykes sells replacement parts for almost all of their products: http://www.littletikes.com/consumerservice/replacementparts.aspx
Just click on "Riding Toys" and choose your Coupe! Steering wheel replacements usually cost around $6-$10.
I hope this helps!
Aug 01, 2011 | Little Tikes Cozy Coupe
I bought an older four sided little tikes climber cube with slide and need help putting slide on!
I might be little late in replying ur query.. u might have even figured it by now.. But this is for the future reference.. here is the assembly instruction of cube climber with slide
http://www.littletikes.com/pdf/4969_4589.pdf
Jun 01, 2011 | Toys
Have a Little Tikes Endless Adventures Mountain Climber. The brown platform has cracked and has a hole in it now. I would like to replace this part.
Regards, Tony
May 17, 2011 | Little Tikes Endless Adventures Look Out...
My cooking creations kitchen didn`t come with an assembly instruction manual
Here is the link to download assembly instructions, though I did not see "cooking creations" listed, you may try entering the exact model number:
http://www.littletikes.com/consumerservice/little-tikes-assembly-instructions.aspx
Note, that Little Tikes does not post all assembly directions- some products do not have them online. However, if you contact them via this form, they can send them to you:
http://www.littletikes.com/consumerservice/Contact-Us.aspx
Just select "Product Help" from the subject field. Good luck to you, hope this helps!
Jan 09, 2011 | Little Tikes Toys
Did not get instructions on how to put the cozycoupe together
click on the green instructions tab halfway down the page. There is also you tube video on how to assemble it. http://www.littletikes.com/toys/cozy-coupe-30th-anniversary-edition.aspx
Jan 01, 2011 | Little Tikes Cozy Coupe
I too need the tunnel for the little tikes 8-1 climber.. Not sure where to look??
You might want to go to the link http://www.littletikes.com/consumerservice/replacementparts.aspx You can order replacement parts at this site. If you are having issues ordering throught this link then call this number 1-800-748-2204. Please let me know if this works for you. This is the contact information for little tikes.
Thank you
May 05, 2010 | Toys
Replacement door for little tikes log cabin
Click on this link it is the replacement site link for little tikes. http://www.littletikes.com/consumerservice/replacementparts.aspx You should be able to click on the product you are looking for a replacement part for and you should be able to find it there.
You can email them and ask for the part that you are looking for as well here is the email address link http://www.littletikes.com/consumerservice/Contact-Us.aspx
Thank you
May 03, 2010 | Toys
Need Instructions
I also needed them. I downloaded them from the Little Tikes website: http://www.littletikes.com/toys/jungle-climber.aspx
Apr 28, 2009 | Computers & Internet
Toys Logo
7,979 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
