Question about Sewing Machines
How to fit my bobbing casing?
I just bought a VIVOTM-1004 serial number# MIC14700055177 sewing machine right before christmas, I just now have time to sew, when I notice that the bobbing casing was not in the casing right. I removed plate to put the bobbing casing back in, that is when I notice that the casing would not fit. I tried to take it back to Walmart where I bought it from. Unforturely they would not replace it. I would like to know if it can be fix.
Posted by Patricia Rieck on
Jimmie Sill
  • Sewing Machines Master
  • 696 Answers
Use your hand wheel and turn it. Monitor under the throat plate. The part you see moving will eventually show an opening. Stop there and install your bobbin casing. If it has a little metal piece across you will have to lift it slightly. After it is snug you can install the bobbin.
Posted on Mar 20, 2015
What year is my Singer Treadle Machine Y9988982
SEE the links
Comprehensive Singer Serial Number Database - Ismacs ismacs.net/singer.../serial-numbers/singer-sewing-machine-serial-number-database.htm... Singer Sewing Machine Serial Number Database. ... Singer has recently pulled some of their dating and identification information from their website. Here you can look up your serial number and find out when your Singer Sewing Machine was made as well as what model you have. ‎G Series Serial Numbers · ‎Y Series Serial Numbers · ‎F Series Serial Numbers
Singer Dating - by serial number - Ismacs
ismacs.net/singer_sewing_machine.../singer_dating_by_serial_number.html Dating Singer sewing machines by their serial numbers.
DATING SINGER SEWING MACHINES. SINGER SERIAL NUMBERS ...
www.sewalot.com/dating_singer_sewing_machine_by_serial_number.htm This is a simple guide to dating your early Singer sewing machines. I do hope you find it useful. Where your Singer has two serial numbers always choose the ...
singer serial numbers Google Search
Aug 08, 2018 | Singer Sewing Machines
What year is my sewing machine serial number EJ682291
Assuming you have a Singer sewing machine, you can find serial number lookup tables here: http://ismacs.net/singer_sewing_machine_company/serial-numbers/singer-sewing-machine-serial-number-database.html . The EJ682291 is a model 99K that started manufacture after May 19 1954.
I hope this helps.
Oct 07, 2017 | Sewing Machines
What year is my singer sewing machine serial number B504484
Singer assigned the B504484 serial number on July 28, 1904. The production line started building the model 27 sewing machine after that. See http://ismacs.net/singer_sewing_machine_company/serial-numbers/singer-b-series-serial-numbers.html .
I hope this helps.
(It can take some time between starting to build the machine and actually shipping it.)
Jul 02, 2017 | Singer Sewing Machines
I have my grandma's old Singer machine. Serial # is G8157312. Would like to know how old it is and what is the value.
June 1920
Value is not easy, but they are not worth as much as you probably think it is.
  • Antiques > Sewing (Pre-1930) > Sewing Machines ' eBay www.ebay.ca > Antiques > Sewing (Pre-1930) Visit eBay for great deals in Antiques > Sewing (Pre-1930) > Sewing Machines. Shop eBay!
  • Miss Sews-it-all: How Much Is My Old Sewing Machine Worth? sewsitall.blogspot.ca/2013/08/how-much-is-my-old-sewing-machine... Antique Singer Sewing Machine Value from Antique Singer Sewing Machines. Submitted by Miss Sews-it-all at 11:20 AM. Email This BlogThis!
    Serial Numbers Comprehensive Singer Sewing Machine Serial Number Database
  • Jun 12, 2016 | Singer Sewing Machines
    What year is my singer sewing machine serial number A248971
    Singer Sewing Machine Company kept accurate records and you will find the answer: ismacs.net/singer_sewing_machine.../serial-numbers
    There does not seem to be any serial numbers that begin with the single letter A.
    Dec 07, 2015 | Singer Sewing Machines
    Adjusting the feed timming in relation to the needle on an alco/necchi model 130054 sewing machine .
    Hello, 130054 isn't the right model number for the sewing machine. Can you get me more info? Can you supply the serial number too or any other numbers on the sewing machine?
    Oct 27, 2015 | Sewing Machines
    How old is my singer sewing machine model 6408
    Get the serial number from the machine--on your machine it should be on the right end, underneath the hand wheel.
    Once you have that, go to the singer sewing machine site and select Support and Resources at the top, and "machine serial numbers" under that.
    Feb 16, 2015 | Singer Sewing Machines
    I bought a dual sew sewing machine, Insturction model says Model DS-2000/DS-3000 from someone that was moving today. They have only used it once. I wanted to start by threading the bobbin. The problem...
    unfortunately if you weren't able to test the machine before purchase you may have bought a dud. depending on where it was stored, it could be seized up. Non the less, any reputable sewing machine repair shop will help you with this specific prob for little or no cost
    Feb 20, 2011 | Sewing Machines
    Sewing Machines Logo
    51 people viewed this question
    Top Sewing Machines Experts
    Chris Wetmore
    Marvin
    Marvin
    Are you a Sewing Machine Expert? Answer questions, earn points and help others
