Question about Goodman Heating & Cooling
My Goodman furnance blowing cold air.I have 4 LED flashing lights
    Master:
  • 572 Answers
Reset the power to see if the furnace tries to light. If it tries & fails, it is an ignition issue ie hot surface igniter, dirty flame sensor. If the LED's still are lit up, it is most likely a limit that is open.
Posted on Mar 21, 2015
6ya staff
SOURCE:
Furnance running all the time never shuts off
Turn the thermostats fan position to Auto instead of ON. If it already is in Auto, then there is a fan relay stuck in the board.
Dec 13, 2013 | Goodman Manufacturing Goodman AEPF313716...
My goodman furnace lights and burners comes on but blows cold air.
To much question.i want to know where is mag box now.
Nov 28, 2013 | Heating & Cooling
Hi,my name is julio i have a problem with my goodman furnance,the furnance run for 10 or 15 minutes and then shut off and come back again for 5 minutes keep do in on and off on and off and then shu off...
it is probably hitting the high limit switch possibly.
Is your filter clean?
Are all the vents in the house full open?
Is your furnace vent (flue Pipes) clean and unobstructed?
Jan 07, 2011 | Goodman GMS90703BXA Heater
My furnace blows cold air constantly even in heat mode. It's led light flashes 4 times in a set, what could it be?
On Goodman furnaces, 4 flashes usually means open high limit. Look for any burnt or loose wires or any resettable limits, they should have a red button that clicks when you push on it and wire going in and out of it with spade clips. If the open limit is not resettable, jump it out to verify its open and if that fixes the problem, replace the defective limit. Best of luck.
Mar 18, 2010 | Goodman GDS80703ANA Open Flame Mid-Size...
Furnace blows cold air, ignitor won't glow.
ok this is going to sound funny but it seems as though the polarity is reversed going into your furnance. to correct this proiblem you first need to unplug the unit and where the cord goes into the furnance at that connection disconnect the two wires. Once theses are disconnected switch the wires .All you are doing is reversing the way the electricity flows into the circut board. I would wager that is the problem
Apr 13, 2009 | Heating & Cooling
Gas furnance won't stay lit.
have a furnace man take a look it sounds like the itermitter control
Feb 05, 2009 | Goodman GMS80904BNA Open Flame Mid-Size...
Led flashes all the time heater won't start
some how the hot and neutral became reversed,i don;t know if it happened when a breaker sparked in the box or what . i reversed the hot and neutral at the input of furnance abd it is working at this time.
thanks for your help
Nov 24, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
109 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Brad Scarpetta
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
