Question about Yamaha Electrical Supplies
What is the valve lash on the mz360 generator engine
Posted by Chad Harris on
1 Related Answer
SOURCE: tecumseh hm-100 exhaust valve never completely
Bent valve stem?
Posted on Apr 01, 2010
Buffalo tools 7000 watt 13hp ohv 4 stroke valve clearance
if you cannot get the specs from on line or from a service agent , generally the following apply:-
water cooled engines
inlet hot .010"--exhaust hot .012"
for air cooled engines inlet hot .012"-- exhaust hot .014"
Aug 30, 2015 | Buffalo Tools Electrical Supplies
HOW TO MAKE VALVE SETTING FOR CAT 3412
i don't have answer to my question how to valve lash the Cat engine
3412 Generating set
May 22, 2014 | Caterpillar 3412E DITA Marine Propulsion...
How to adjust valve lash on a 1990 Geo Storm
its an Isuzu engine.
there are 3 engines.
4XE1, SOHC 1.6L (base)12valves
4XE1, DOHC , 1.6L same as above but now with 16valves.
4XE1, DOHC, 1.8L bends valves if belt snaps...
note the bad idea of ISUZU calling all 3 engine same name.
a horrid idea.
which one? the second was in USA and Canada only.
the second one was offered as the GSI. is yours that?
so I will attempt to guess for you, its the base engine.
(odds of coin toss)
toss #2, USA, SOHC
guess 3: did a new belt and want to do lash next. Cam belt>
No job stated so i guess 3 times.
Just lash.
SOHC 1.6L only (FSM book quote)
Check the valve lash between the rocker arm and valve stem on both the intake and exhaust valves on the number 1 cylinder, the intake valve(s) on the number 2 cylinder and the exhaust valve on the number 3 cylinder. If the valve lash on the intake valves is not 0.006 in. (0.15mm), adjust the valve lash. If the valve lash on the exhaust valve is not 0.010 in. (0.25mm), adjust the valve lash.
1.6L twin cam has shims.
1.8L has HLA , no lash to set.
HLA= Hydraulic Lash adjusters.
I posted this before, search for it. Im only doing 1 engine.
Apr 12, 2014 | 1990 Geo Storm
Caterpillar 3412e valve lash adjustment
Contact JD Marine in Fort Lauderdale FL they can possibly get you the information, or sell you a service manual
Apr 03, 2013 | Caterpillar 3412E DITA Marine Propulsion...
Need to know how to adjust the valves
On Vehicle Inspection If a clanging noise due to the lash adjuster produced immediately after the engine has started or during operation persists, perform the following checks:
  1. Check the engine oil, and add or replace if necessary.
    1. If the engine oil is low, the air drawn in from the oil strainer will be trapped in the oil passage.
    2. If the engine oil level is higher than the specified level, agitation of oil by the crankshaft could cause a large amount of air to enter the oil.
    3. A deteriorated oil contains a large amount of air, because the air, once trapped, is not readily separated from the oil. If the air trapped due to these causes enters the high pressure chamber in the lash adjuster, the air in the high pressure chamber will be compressed while the valve is in the opened position. The lash adjuster will be drawn too far in, and will produce noise when the valve closes. This is the same phenomenon that occurs when the valve clearance is adjusted to an excessive dimension. Fig. 1: Check the valves with the white arrows, rotate the crankshaft 360°, then check the valves with the black arrows — 2.0L, 2.3L, 2.4L and 2.6L Engines 86663205.gif
      Fig. 2: Check the valves with the white arrows, rotate the crankshaft 360°, then check the valves with the black arrows — 3.0L (12 Valve) Engines 86663206.gif
      Fig. 3: Check the valves with the white arrows, rotate the crankshaft 360°, then check the valves with the black arrows — 3.0L (24 Valve) Engines 86663236.gif
      Fig. 4: Check the valves with the white arrows, rotate the crankshaft 360°, then check the valves with the black arrows — 3.5L Engines 86663207.gif
      Fig. 5: Push the rocker arm to check if the rocker moves down or not — all engines except for the 3.5L Engines. 86663208.gif
      Fig. 6: Push the rocker arm to check if the rocker moves down or not — 3.5L Engines. 86663210.gif
      In this case, the normal condition will be restored if the air escapes from the lash adjuster.
  2. Start the engine and slowly race (accelerate the engine from idling speed to 3,000 rpm in 30 seconds and then decelerate it to the idling speed in 30 seconds) it several times (less than 10 times). If racing the engine causes the noise to die away, it means that the air has escaped from the high pressure chamber of the lash adjuster and that the lash adjuster has regained its normal functions.
    1. When the vehicle is parked on a slope for a long period of time, the oil in the lash adjuster will decrease. When the engine is started, the air might enter the high pressure chamber.
    2. After a long period of parking during which the oil in the oil passage goes away, it will take some time before the oil is re-supplied to the lash adjuster. Therefore, the air could enter the high pressure chamber.
  3. If any abnormal noise is not eliminated by racing, check the lash adjuster.
    1. Stop the engine.
    2. Set the engine so that cylinder No. 1 is positioned at the top dead center of the compression stroke.
    3. Press the rocker arm at the area indicated by the white arrow mark to check whether the rocker arm is lowered or not.
    4. Slowly turn the crankshaft 360°clockwise.
    5. In the same procedure as step "c'', check the rocker arm at the area indicated by the black arrow mark.
    6. Push down the rocker arm at a portion located right above the lash adjuster. If the rocker arm goes down readily, the lash adjuster is defective. Replace it with a new one in accordance with Step 4. In addition, when replacing the lash adjuster, be sure to remove air positively from the lash adjuster before installation. Then perform inspection in accordance with steps "a'' through "e'' to make sure that there is no abnormality. In addition, if the rocker arm is felt to be very stiff or cannot be pushed down when it is pushed, the lash adjuster is in the normal condition. Therefore, check for other causes of noise.
Bleeding and Checking When cleaning or checking the lash adjusters, use only clean diesel fuel. To test the lash adjusters, follow this procedure.
  1. Immerse the lash adjuster in clean diesel fuel.
  2. While lightly pushing down the inner steel ball using a small wire, move the plunger up and down four or five times to bleed air. The use of the retainer facilitates the air bleeding of the rocker arm mounted type lash adjuster.
  3. Remove the small wire and press the plunger in. If the plunger is hard to be pushed in, the lash adjuster is normal. If the plunger can be pushed in all the way readily, bleed the lash adjuster again and test again. If the plunger is still loose, replace the lash adjuster. NOTE: Upon completion of bleeding the air out of the lash adjuster, hold the adjuster upright to avoid the diesel fuel from spilling.
  4. After air bleeding, set the lash adjuster on the special tool (leak down tester MD998440).
  5. After the plunger has gone down somewhat 0.008–0.020 in. (0.2–0.5mm), measure the time needed for it to go down an additional 0.04 in. (1mm). Replace if the measured time is not between 4–20 seconds.
Sep 06, 2010 | 1991 Mitsubishi Mighty Max
Tecumseh hm-100 exhaust valve never completely closes
this is a strange problem, the engine would not have left the factory in this condition. are the cam followers the same size ? have they been mixed up.
some engines have an auto decompression which consists of a spring loaded centrefugal weight on the camshaft gear and in order to close the valve the engine has to reach a certain cranking speed in order to compress
Apr 06, 2010 | Coleman Powermate Powermate 5000W...
WHERE CAN I GET YAMAHA MZ360 IN SOUTHAFRICA,JOHANNESBURG .I AM IN ZIMBABWE,BULAWAYO
Unit A4 The Palisades Business Park 39 Kelly Road Jet Park East Rand, Joburg (Come visit us Mon-Fri: 7:40-16:00);
Dean Webster Charles Stuart Cell 0837015332 Cell 0833071580 Fax 0118809089 Fax 0118809089
Jan 27, 2010 | Coleman Powermate Premium Plus 6250W...
McCULLOCH FG2000Tc engine starts but idle
Check the valve clearances with a feeler guage. Over time the valve lash adjustment vibrates a little looser than we want and the engine gets hard to start, runs rough, etc. After the engine warms up the heat makes the valve tappets expand enough to make the engine smooth out.
Regards,
Carl
Feb 26, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Electrical Supplies Logo
141 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Robert Wooley
Robert Wooley
Dan Horsefield
Dan Horsefield
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
