Which models of access points can WS-C3850-24T-S support?
Three months ago, I bought the new switch WS-C3850-24T-S, now I want to buy some AP for the switch, does anyone know which models supported?
Posted by emmalee on
GuoJames
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
The following models of access points are supported: LAP1040, LAP1142, LAP1260, CAP3700, CAP3500, CAP3600, CAP2600, and CAP1600, AP700I, AP700W, AP2700 and AP1530 (No mesh). And you can bought the AP products with 40%-80% OFF at 3Anetwork.com. Good luck to you.
Posted on Mar 20, 2015
Testimonial: "thank you for your quick reply, I known 3Anetwork.com from my friends, too, they said it's a professional Cisco supplier."
Zyxel
OK here's the user guide. Page 33.
The problem is going to be if your wireless source for the AP's connection will allow an access point to attach to it.
You also have to remember that the AP is considered an attached device by the main router. That means no NAT, no DHCP, no nothing from the AP but a relay of the main router. It has to be on the same IP address level. If you follow the instructions to the letter it should work.
Mar 27, 2014 | Zyxel WAP3205v2 Wireless N300 Access Point
Inability to gain access to ap store on my iPad2
Go to Settings - General - restrictions, and make sure Installing Apps is set to On.
Mar 27, 2014 | Apple iPad Tablets & eReaders
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
I have a motorola AP-300 which keeps on blinking amber light when i turn it on. how can i reset it or what's wrong with the AP?
From the installation guide for this AP, I find the following:
LED Indicators
The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
802.11a Activity LED Amber
The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
802.11b/g Activity LED Green
The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
From this, it appears that the 802.11A radio is malfunctioning.
Here is the Motorola support web page for this device.
Dec 30, 2010 | Motorola AP300:802.11A/G, Internal Antenna...
Connect belkin f5d7130 to homehub 1.5
You need to connect all pc's and homehub to a switch so they can talk to one another. Then use the AP as a wireless access point to connect all wireless laptops, and connect the AP to the switch with ethernet cable, and you have a network. Just make sure that only your HH or AP supplies IP addresses or they will clash.
Oct 19, 2009 | Belkin Wireless (F5D7130) 802.11g/b...
Can I use a D-Link DI 634M as an access point?
Sure you can! As you can with any wireless router pretty much.
1. Assign the new router (AP) to an IP on your subnet that's not your existing router's IP... i.e. 192.168.0.2
2. Disable the DHCP server on the "AP"
3. Create a new wireless network on the "AP"
4. Plug your existing network/router into a LAN port
DO NOT USE THE WAN PORT
Voila! You have an access point!
Jun 21, 2009 | D-Link DI-634M Wireless Router (DI634M)
Need a new screen and protection screen for Mits ws 55513 where can i get one or is it cheaper to buy a new tv
the only solution u have is to call all tv repair shop and see if they have a use screen with the same model ,
Jan 16, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Self-assigned IP address and may not be able to connect to the Internet
if its a wireless network it assigns yyou an ip immediately solong as you are not connecting directly so dont bother about the ip just connect and see what happens.
Oct 27, 2008 | Lucent ORiNOCO AP-500 (8485878380)
DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
Aug 07, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
Computers & Internet Logo
268 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
