Question about Pyle Dryver PLAD213 Car Audio Amplifier
Pyle dryver amp light protection stays on not green light stays red i have tried to disconnect everything and plug it back up but light stays red
Posted by keith_ric699 on
Anonymous
    Problem Solver:
  • 10 Answers
Check your subs disconnect them the try to power the amp up if it powers up the the subs have died and it could be a problem with that amp i suggest you get a better amp
Posted on Jul 11, 2009
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Mar 01, 2012 | MTX ThunderĀ® TC8001 Car Amp
I cannot stay connected to internet, my model 2701HG-B 2wire at&t dsl will start flashing red then disconnect me from the internet or my game site, how can i get this to stay fluently connected please!
You might want to try disconnecting everything EXCEPT the power cord. If you still get the red power light (it should stay there forever) then bring the gateway to Radio Shack or somewhere they have a 5 volt DC @ 2 amp power supply and plug it in for 5 to 10 minutes and see if the power light then stays green. If it stays green then all you need is a new power supply! If not, then the gateway is fried. Mine keeps going from a solid green power light to a flashing green power light and I can hear a relay click every 2 minutes at which time a pop-up say "ethernet line disconnected". I tried new power supply etc. to no avail! It is fried after 1.5 years! No more 2wire for me!
Sep 28, 2010 | 2wire 2700HG-B Router (2700HGB)
Red protection light stays on all time....
try disconnecting one at a time each speaker till the red turns to green. One of your speakers may be bad. Amp is just telling you that its clipping and overheating due to the change in ohms of a shorted or bad speaker. Its also possible the amp is on its last leg due to heat. Heat breaks down electronics part and eventually get worse.
Apr 05, 2010 | Car Audio & Video
Amp not working
I had a similar problem with a pyle amp. try to disconnect the speakers and turn it on if the protect light doesn't come on then you might have blown something in your amp and it needs to be repaired. For my situation it was a blown resistors and only 1 channel worked. If you don't have soldering experience then I wouldn't bother trying to fix yourself, an unsteady hand can ruin your repair.
Mar 26, 2010 | AudioBahn A8000T Car Audio Amplifier
AMP LIGHT STAYS ON PROTECTION
shorting out check your speakerwires, or a bad speaker, remplace them
Jul 09, 2009 | Pyle Dryver PLAD213 Car Audio Amplifier
LIGHT RED PROTECTION
missmatched impedance, insufficient grounding or blown transistor/other internal problem within the amp.
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Amp shut down no power
If the red light is the protection LED, the amp probably has shorted output transistors. Read through the following page to eliminate other possible causes.
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 13, 2008 | Pyle (DBPLA2480) Car Audio Amplifier
Protect led light
It appears that the amp is going into protect mode. To eliminate external causes, read through the following page. Let me know if you have any other questions.
Oct 10, 2008 | Car Audio & Video
1200 watt legacy amp not working right
your amp its protect by releas of [powerout]one this releys is dead you mast chenche
Apr 14, 2007 | Pyle Dryver PLAD213 Car Audio Amplifier
Pyle Dryver PLAD213 Car Audio Amplifier Logo
297 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Sheldon Dedek
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
