Possibly the hand brakes dragging.
With a normal handbrake, you can remove some screws around the handbrake covering. The screws are sometimes well hidden so you have to look around.
When you get the covering off, there are two adjusting nuts at the rear of the handbrake. Turn the nuts until you can get "5 clicks" on the handbrake to set the brakes.
Some jack up the car while doing this so they can rotate the wheels by hand to feel when the brakes touch the pads.
Hope this helps
There are a number of issues that can cause overheating disc brakes. Disc brakes, when released, separate from the disc by the action of the rotor moving between them (since no rotor is perfectly true, there is a small about of wobble and it pushes the pads away from the rotor surface). Things that can cause this to go wrong are:
It is highly recommended that whenever you change your brake pads, you replace the caliper slide bolts use a new brake hardware kit when reinstalling. The additional cost is almost always saved in longer brake pad life, and fewer complications.
