Question about Spirit XE195 Elliptical Trainer
Hi i have in the screen ERR what i can do in the manual dont explain it Help
Posted by claudia cruz on
gbob59
  • 3,063 Answers
Try this: There appears to be diagnostic software in the unit.
http://www.manualslib.com/manual/633896/Spirit-Xe195.html?page=20#manual
Posted on Mar 19, 2015
Testimonial: "i will do, thanks!"
Hi just had my car serviced and the battery was disconnected and now i dont remember my radio code it keeps coming up err, could u please help me
You can check up with your dealership for the codes or see if this written down inthe service manual/booklet. If not the delearship can guide you from the database .
If there is no help please check this link:
http://www.radio-code.com/
http://www.floodle.net/extra/ebayinfo/car_radio_decode.html
Aug 18, 2011 | Car Audio & Video
Hello, I am trying to figure out why it says Err at the top right corner of the screen, It wont let me take any pictures... I tried playing around with all the setting any everything, taking the film out...
The film is not inserted correctly. pull film leader out until it just reaches the red line on the take up spool, then close the bacl. "ERR" should be gone
Jan 29, 2011 | Nikon N55 35mm SLR Camera
ERR comes on screen...
Pull all the batteries, wait 30 seconds, put in a completely different card, put batteries back in and turn on and format the card--sometimes works
Aug 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
Kenmore dehumidifier model 129-25803. I am getting err 3.
Hi, In the manual it says if you get this error err 3, please contact your authorized dealer. Hope this helps.
Jul 20, 2010 | Kenmore Dehumidifiers
I have a D80 since 2 years and since last 1 week have been getting the 'Err' message. Initially, after referring to the manual & pressing the shutter release button, the camera responded only ONCE. ...
Hi sandeepbhat2, On page 129 of the D80 manual is the factory reset switch. Look on the left side of the camera there is the terminal cover, inside below the USB connector is a small reset button. Give that a try. If still it does not work you should call Nikon.
Jun 27, 2010 | Nikon D80 Digital Camera with 18-135mm...
My nikon camera keep got error and dont have the
You have not provided enough information, what is the error read? If it shows ERR then: The ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
Mar 24, 2010 | Nikon D80 Digital Camera with 18-135mm...
Wont take picture, Top screen says ERR. It's a D50
If it's a problem in AF and M mode it is an indication that it is probably your shutter. I have heard of similiar problems. Best bet is to call Nikon and explain your problem. Might have to send it in to be repaired or replaced.
Please rate!
Cheers
Oct 04, 2009 | Cameras
Sabb fixed...now err with temp.
posssible that youve now switched from farrenheit, to celcius. manual will explain how to shift back
Feb 26, 2009 | KitchenAid KESC307 Electric Kitchen Range
Resetting the radio code in a 1998 falcon
The dealer has to send the radio out to their authorized service rep to hve the EPROM in the radio re-flashed with a new code.
These radios have no master key code. They were designed to be very secure.
Jerry G.
Jul 11, 2008 | Ford Futura Cars & Trucks
Spirit XE195 Elliptical Trainer Logo
168 people viewed this question
Top Spirit Exercise & Fitness Experts
gbob59
Marvin
Marvin
john h
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
