Factory reset KM bizhub C252
I somehow messed up access to the printer connection from my computer. some protocol issue. How do I factory reset network settings so I wipe out my mess? Pls be specific and assume no knowledge of hardware. thx
Posted by rpalpha on
Norman J Weimar Jr
  • Office Equip... Master
  • 6,960 Answers
Utility/counter select admin (password 1234678 or 0 x 8) default select network.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jun 03, 2015
5 Related Answers
Anonymous
  • 214 Answers
SOURCE: Can't Network Print
in printer you should log in as administrator and there should be network settings, where you can put in ip address and gatway and so on.
Posted on Dec 05, 2007
copierhell
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Posted on Dec 20, 2007
Anonymous
  • 167 Answers
SOURCE: Bizhub C252 -- printer defaults not retaining account tracking passwords
when you create account codes they are assigned a number, are you sure you are not starting at the end? It should only erase the previous information if you turn account track on then off.
[email protected]
Posted on Jan 08, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
It is supported for Vista according to this chart
Here is the drivers for 32 bit Vista
Posted on Jul 06, 2008
Anonymous
SOURCE: Canon MF4370dn Network Multifunction Laser Networking setup prob
I never figured out how to reset the machine but I figured out what I messed up on. I accidentally toggled the MAC address RX Auto to off. This means you must specify the MAC address of the machine you want to access it. This is why my computer could not find the printer. I went into the settings on the machine and changed it to auto and it works great.
Posted on Jan 03, 2009
Konica Minolta BizHub C252 - pale colors on the long side
Konica Minolta BizHub C252 Repair Questions,... - Fixya
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
How to clean the drums/i units on the konica minolta number ...
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
Dec 14, 2015 | Konica Minolta BizHub C252
My bizhub c252 keeps reading low toner for yellow, and after a few copies it reads no toner and has to be reset to continue working. What is the problem
you may have to get into the printer settings on your PC and tell the printer it has a new cartridge installed. the easiest way is to open the computer folder and right click your printer and select properties. you can also go to start-control panel-hardware and sound and select view devices and printers then right click your printer and either select printer properties or troubleshoot. troubleshoot may give you an answer or idea how to correct the toner issue
Nov 24, 2014 | Konica Minolta BizHub C252
I have a Bizhub C252 with the code C3452. How do I reset the machine back to factory settings?
MINE YOU THAT IF THIS PROCEDURE DOES NOT WORK DO NOT RESET GAIN YOU ARE DEALING WITH THE FUSER IT CAN CATCH ON FIRE THAT WILL RUIN A PERFECTLY GOOD DAY!!!!!!!! have tech come out replace the fuser
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Apr 13, 2014 | Konica Minolta BizHub C252
I have a Konica/Minolta bizhub c252 with the c 3452 code on the panel. How do I reset the machine to factory settings?
Sir/Mam
Apr 13, 2014 | Konica Minolta bizhub C250 All-In-One...
Bizhub C252 factory reset
if you mean to initialize the machine then go to service mode, then go to system 1, from there you can initialize the machine settings to factory settings.
Nov 20, 2012 | Konica Minolta Bizhub c203 Copier
Printing to bizhub c252 from one computer a problem
s it a shared printer? if it is, install the driver as a local printer
May 27, 2010 | Konica Minolta bizhub C250 All-In-One...
KM C252 - I'm trying to print postcards on 110 lb cardstock, but the ink doesn't stick. It made a huge mess.
You need to set the paper settings to a HIGHER weight/gsm. It is running for thinner stock so the toner is not fusing to the paper properly. you will need to use a thick 3 at least.
Feb 28, 2010 | Konica Minolta bizhub C250 All-In-One...
I HAVE A KONICA MINOLTA BIZHUB C351, I WAS MESSING WITH THE NETWORK CONFIGURATION AND NOW I CAN'T PRINT, IS THERE ANY WAY TO RESET IT TO FACTORY CONFIGURATION??? ANY HELP PLEASE...
First of All, Assign an IP address to the machine, if you already assigned the IP address, then Ping it from one computer to check its connectivity, now remove all the printers and printer drivers from your computer, and re-install the printer. if you want to reset the machine, then press the "utility/counter" button and turn the machine ON,(keep the button pressed) now from that machine reset the machine.
Feb 27, 2010 | Konica Minolta bizhub C351 All-In-One...
275 people viewed this question
jasbo
jasbo
Marvin
Marvin
