Question about Radio Shack Accurian APD-3955
We purchased an HD Radio and find that it cuts in and out...can one connect the radio to an outdoor Antenna to resolve the situation
Posted by paulbortnem on
Bill Buchsbaum
    President:
  • 2,761 Answers
Absolutely, as long as the radio has connections for an auxiliary antenna. You can also connect to an indoor antenna that's a lot better than the wire antenna that your set comes with. For options, try searching eBay for FM antenna.
Posted on Aug 29, 2009
Have a bose wave and live in a metal building. Can't get hardly any am fm radio recept. 3.5 mm antena jack. Can I get an am fm antenna? And do I need to mount antenna outside?
The Bose has the option for external antenna, but uses the AC cord as the antenna, so first try stretching your AC cord to its fullest extent in a straight line, then in different directions to see if that improves the situation. This is for FM only. The AM uses an internal ferrite rod antenna, and this is sensitive to direction, so try rotating the radio in different directions to see if signal improves on AM, and place unit as near a window as possible.
If none of this helps, you will be able to use an external antenna, and no it is not mandatory that they be mounted outside ... as long as you have room indoors. In fact, several manufacturers market indoor antennas for apartment dwellers and others under restrictions against mounting antennas outdoors.
But, logically, the best way to improve reception is the largest antenna mounted as high up and as far away from obstructions between the antenna and transmitter as possible.
Good luck.
Don Miller, CET
CET Services
Bose Wave Radio Repairs
[email protected]
Apr 30, 2016 | Bose Audio Players & Recorders
Cd player work but no radio
Assuming the vehicles antenna is intact and in one piece, check the antenna connection behind the radio. If the antenna is connected behind the radio, there could possibly be a problem with the radio's tuner (internally). The only way to properly diagnose this problem is to place a radio that is known to work into the vehicle (simply to test) and check the radio reception. If the radio reception is improved and working, you know the problem lies within the radio itself.
If it still does not work, there is a problem with the antenna on the vehicle (disconnected, damaged, cut, etc.)
Mar 21, 2016 | Cars & Trucks
My 1990 Honda Accord radio antenna motor functions opposite to what it is suppose to be. When radio is on the antenna down, when the radio is off antenna up. Even with this reverse function I can feed the...
first of all, is your radio factory or aftermarket? If its factory the you probably have a bad ground or a short in the radio power to antenna. If its after market, then the remote antenna wire is hooked up wrong. Check to make sure the antenna wire is hooked up to the antenna. Good luck
Feb 21, 2011 | 1990 Honda Accord
I had a 98 toyota tacoma with a completely different radio system and where i used to have perfect service connection to a radio station and now with my 2001 ford focus and the jvc kd-g140 radio i barely...
Hi Sarah,
The problem will lie with one or combination of the radio, the antenna or antenna cable. Check the antenna. If it is the type that can be unscrewed from the body of the car, do so. Check and clean any mating surfaces. Dirt & oxidation are enemies of electrical connections. Check the antenna cable everywhere it is exposed. Look for cuts in the jacket which can allow water in and causes oxidation. Check the connection at the radio, too. Make sure it is free of dirt and oxidation too. Clean the connectors and reconnect. Be sure that the plug connections are fully seated in the jacks. If you find a damaged cable or connector, it should be replaced. many times, replacing the cable will be very difficult - you might want to try installing a new antenna and cable instead of trying to reuse the old antenna. These are often available for sale in the automotive sections of department stores, and in automobile specialty stores. Try connecting everything together to make sure it works before punching holes in the body of the car.
The issue may be the radio itself. Try connecting a different radio - either an identical factory radio that is known to be good - or an aftermarket radio to is also known to be good. All of these issues can be a logical point of failure - especially if you purchased the car used. There's no telling how the car's radio and antenna might have been used or abused before you took ownership of the car.
Nov 22, 2010 | JVC KD-G140 Car CD Player
Where can you purchase a replacement antenna for
I just replaced my broken antenna for my CFD-S350 by calling Sony Parts and Support at (239) 768-7691. Cost only $7.99 and that included the $2.00 shipping charge.
Jun 03, 2010 | Sony CFD-S350 Radio/Cassette/CD Boombox
Put radio in car lost memory but when i go to tune it in it goes fast past all stations how do i make it go slow to find stations
First things first. Did you connect your antenna? Does your radio need an HD Radio accessory? Check your owners manual. I went through similar issue. Antenna was hooked up, but radio stations were flying by when searching. Come to find out I needed an HD Radio Accessory. Let me know how this works out for you.
Sep 19, 2009 | Kenwood Car Audio & Video
Digital tv
Good Day, tuff65;
Today with "HD TV" get a good UHF/HD antenna. You can get at any local Best Buy, Circuit City, Radio Shack etc.
Good Luck, big IRISH. PS: Inside or outdoors.
Sep 03, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Can't Get A Radio Signal When I Connect A Cox Cable
Hi...
Some cable companies dont put the FM band on cable and some others put an FM trap (which kills the FM band) in line with the cable.
One of those is your problem.
You'll need to buy a FM antenna
Jul 25, 2008 | Sony STR-DE597 Receiver
Radio cable length from rear aerial
no - the factory cable is a one piece cable to the radio- what you can do is to cut off the end that went to the original antenna replace it with a female antenna end and just plug the new antenna into it (easiest way)
Mar 24, 2008 | Car Audio & Video
Sirus radio
I had the same problem and I replaced my car antenna. That resulted in immediate signal improvement. But three months later, the same thing. So, another dot micro car antenna. Three months later, the signal went out again. The home kit worked perfectly. In my case, I bought a Sirius outdoor home antenna and replaced the standard indoor/outdoor antenna that came with the home kit. I took the home kit antenna and connected it to my S50 car kit and positioned the antenna on the front of the dash. No problems since then. Not one. Those dot antennas are horrible. I'd check that before getting a new radio.
Jan 13, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Radio Shack Accurian APD-3955 Logo
118 people viewed this question
Top Radio Shack Televison & Video Experts
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
