The unit apparently does not charge. The rim lights up and a little lightning bolt crosses the charging light.The PC sounds like it is recognizing the unit but it is not seen by Explorer. The Zen software says that the unit is not connected. I changed the connecting cable with no improvement. Thanks
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
The red light indicates its charging. My guess is that the battery is dead and will nto hold a charge. This is an older model phone and the lives on the batteries is 1-3 years at most.
If the lightning bolt continues flashing and never stops there is a failure in the flash sub-system. Try selecting the no-flash setting, if the camera fires normally at this point then your problem is definitely in the flash system. It is hard to say what the failure is beyond that. The problem is the camera will not take the picture until the flash is charged and ready to fire - the flashing lightning bolt indicates that it is charging the flash. The fact that it just keeps flashing indicates that the flash is never becoming ready. This repair could cost $68 to $125 plus parts to fix, although an evaluation would be necessary to identify the problem.
