Question about Intel Computers & Internet
Why is pcouffin device for amd 64 bits systems showing up on my ASUS Laptop running Windows 7 64-bit with an intel dual-core i5 chipset?
Posted by Jonathan Fox on
Huseyin Huseyin
  • Intel Master
  • 3,469 Answers
It may refer to the fact that your machine has an AMD graphics card
Posted on May 25, 2015
5 Related Answers
Anonymous
  • 849 Answers
SOURCE: Product comparison
deal 2 is definatly better, go for it
Posted on Oct 28, 2008
Anonymous
  • 44 Answers
SOURCE: AMD Phenom II X4 945, clocks at 800Mhz/core
use Easy Tune 6 to increase the core clock speed
Posted on Sep 27, 2009
WhiteFox4
Keith Fox
  • 641 Answers
SOURCE: hi,i have a hp g6000 laptop with a compaq f700
The reason it shows the compaq logo is because that is the motherboard you have installed. HP is just your case if I am reading your question properly. Did you custom build this? Which processor is in it? Probably the wireless card isn't being recognized because of your 64 bit operating system. Windows 7 has a lot of hardware driver problems right now.
Posted on Jan 03, 2010
Anonymous
  • 25 Answers
SOURCE: i am installed windows 7 64 bit os in my system.
Download the drivers from Asus. http://support.asus.com
Also make sure in your Bios your HD audio is not set to front panel.
Posted on Jan 25, 2010
omerboo
omer cetin
  • 424 Answers
SOURCE: asus p5q pro
Asus P5Q Pro Drivers download link.
Easy come
Posted on Jan 03, 2011
Why is pcouffin device for amd 64 bit systems showing up on my ASUS Laptop running Windows 7 64-bit with an intel dual-core i5 chipset?
It is a low level driver for CD's and DVD's supplied as part of some softwares.
See this page for ore information.
What is Pcouffin
It is not a virus, but check the file sizes mentioned. The message is misleading as it means X64 systems, not just AMD.
Mar 18, 2015 | ASUS Computers & Internet
Contact form
i want the password to be dominic20
Sep 18, 2013 | Acer Extensa Computers & Internet
Can I upgrade video card of asus k42f?
Your laptop graphics card can't be upgrade.It is integrated on your laptop's motherboard.
Jun 22, 2011 | Computers & Internet
I would to know if asus mother p5kpl am se iscompatible with window 7 ultimate 64 bits
yes it is. =) as long as your processor is compatible with windows 7 ultimate. this is the specs of your motherbard and I think it is pretty cool:
- Intel® Core™2 Extreme / Core™2 Duo Ready
- Intel® Quad-core CPU Ready
- Intel® 45nm CPU Ready
- G31+ICH7
- FSB 1333/1066/800MHz
- Dual-channel DDR2 800/667
- 4x SATA 3Gb/s
- Gb LAN
- 6-channel HD Audio
- EZ Flash2 & CrashFree BIOS3
please rate how this helped you.
May 26, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
I recently updated to windows 7 from vista. im having loads of problems with my intel chipset with integrated graphics...i got the windows 7 drivers for it already and im still having problems idk if its...
You'll need to access the computer manufacturer's support site to find the appropriate 64-bit driver for this chipset. If you post the make/model of computer I can probably assist with that.
Hope that's helpful.
Jan 06, 2011 | Intel Pentium Dual Core E2140 / 1.6 GHz...
Asus notebook windows 7 totally frozen..."not responding" Can't even exit without holding power off.
This is due to the fact that your ASUS Eee PC 701 PC does not offer minimum System requirements to run windows 7
Microsoft has published their minimum specifications for a system running Windows 7
as
  • 1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 GB RAM (32-bit) / 2 GB RAM (64-bit)
  • 16 GB available disk space (32-bit) / 20 GB (64-bit)
  • DirectX 9 graphics processor with WDDM 1.0 or higher driver
But I suggest following as min to run smoothly
  • A Dual Processor (AMD or Intel) – you can use a lower Celeron or Pentium Processor, but you will regret it
  • 2 GB RAM (operating memory) – you can use less, but you will regret it
  • 16 GB available disk space and another 20 to 30 GB if you plan on running applications
  • A Vista compatible graphics card (DirectX 9 graphics process with WDDM 1.0 or higher)
  • A Vista compatible sound card
  • Vista drivers for any other unique hardware you have on or connected to your computer
If this helps please do leave a vote and rate for the solution.
Feb 21, 2010 | ASUS Eee PC 701 Notebook
I can upgrade to windows 7 in my n1000
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Personally i would recommend to upgrade ram then install win 7
Regards
Uttam
Windows 7 requirement If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx
Here is you laptop spec
Processor Processor Intel Pentium M 733 / 1.1 GHz
  • Core voltage technology Ultra Low Voltage (ULV)
  • Data bus speed 400.0 MHz
  • Processor features Enhanced SpeedStep technology , Power-optimized processor system bus
  • Chipset type Intel 855GME
Cache Memory Type L2 cache
  • Cache size 2.0 MB
RAM Installed Size 512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
Video Graphics Processor / Vendor Intel Extreme Graphics 2
  • Video Memory Dynamic Video Memory Technology 2.0
Operating System / Software
  • OS Provided Microsoft Windows XP Professional
  • Software Drivers & Utilities
Dec 10, 2009 | Averatec 1000 Notebook
How can I change the resolution from 1280 x 800? This is the highest possible according to the display setttings. I have removed the generic pNp monitor. I am running Vista Business. The display adapter is...
Graphics Unable to use the native resolution, such as 1920x1080, 1680x1050 and 1440x900 circuit388.gif Symptom(s):
On some displays, users may be unable to use the native resolution when using Intel® chipset graphics. Resolutions such as 1920x1080, 1680x1050, and 1440x900 are not available in graphics properties.
Cause:
The display's EDID is not read properly when connected to some digital flat panel displays. Display devices describe its capabilities by sending EDID (Extended Display Information Data) to the computer.
Solution:
Intel has released a graphics driver to specifically address this issue; however, there may be side effects to this solution such as longer than normal resume times from standby. This solution will only work with external displays such as DFP displays connected to the computer's VGA port. This driver is not designed to address issues with a notebook's built-in display (Local Flat Panel) or with TV’s connected to the system. This driver is provided as is. Intel has not tested, and does not guarantee, the operation of the driver for this purpose.
For the desktop and Mobile Intel® 945 Express Chipset Families:
If you have a computer that has the Intel® 945G or 945GV Express Chipset or the Mobile Intel® 940GML, 943MGL, 945GM, or 945GMS Express Chipset, click here for drivers that resolve this issue.
For the Intel® 3 Series Express Chipset Families and the Mobile Intel® 965 Express Chipset Family:
If you have a computer that has the Intel® G31, G33, G35, Q33, Q35 Express Chipset or the Mobile Intel® 965 Express Chipset, click here for drivers that resolve this issue.
For the Intel® 4 Series Express Chipset Families:
If you have a computer that has the Intel® G41, G43, or G45 Express Chipset or the Mobile Intel® GL40, GM45, or GS45 Express Chipset, click here for drivers that resolve this issue.
For the desktop Intel® 946 and 965 Express Chipset Families:
If you have a computer that has the Intel® 946GZ, G965, Q963, or Q965 Express Chipset, click here for drivers that resolve this issue.
How to identify your Intel® graphics controller
How to install the graphics driver
I cannot select a larger display mode (resolution, refresh rate, or color settings). How do I resolve this issue?
Error: "The driver being installed is not validated for this computer..."
Operating System:
Windows XP Professional x64 Edition*, Windows Vista 64*, Windows Vista*, Windows Vista 32*, Windows 7*, Windows 7, 32-bit*, Windows 7, 64-bit*, Windows 7 Enterprise, 32-bit version*, Windows 7 Enterprise, 64-bit version*, Windows 7 Home Basic, 32-bit version*, Windows 7 Home Basic, 64-bit version*, Windows 7 Home Premium, 32-bit version*, Windows 7 Home Premium, 64-bit version*, Windows 7 Professional, 32-bit version*, Windows 7 Professional, 64-bit version*, Windows 7 Ultimate, 32-bit version*, Windows 7 Ultimate, 64-bit version*, Windows XP Professional*, Windows XP Home Edition*, Windows XP Tablet PC Edition*, Windows XP Media Center Edition*
This applies to: Intel® 3 Series Chipsets
Intel® 4 Series Chipset
Intel® 82945G Express Chipset
Intel® 82946GZ Graphics Controller
Intel® 82G965 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q963 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q965 Graphics and Memory Controller Hub (GMCH)
Intel® 945 Express Chipset Family
Intel® 946 Express Chipset Family
Intel® G31 Express Chipset
Intel® G33 Express Chipset
Intel® G35 Express Chipset
Intel® G41 Express Chipset
Intel® G43 Express Chipset
Intel® G45 Express Chipset
Intel® Q33 Express Chipset
Intel® Q35 Express Chipset
Intel® Q43 Express Chipset
Intel® Q45 Express Chipset
Mobile Intel® 4 Series Express Chipset Family
Mobile Intel® 945 Express Chipset Family
Mobile Intel® 945GM Express Chipset Family
Dec 06, 2009 | Acer TravelMate 5730-6204 Notebook
What are the compatible processor for asus p5p800 mx
Asus P5P800-MX Motherboard Features
64bit CPU support
64-bit computing, the next generation technology to replace current 32-bit architecture, delivers advanced system performance, faster memory access and increased productivity. This motherboard provides excellent compatibility and flexibility by supporting either 64-bit or 32-bit architecture.
Intel EM64T
Intel EM64T (Intel Extended Memory 64 Technology) allows processors to run newly written 64-bit code and to access larger amounts of memory, which delivers exceptional graphic performance and higher data processing speed. Digital media applications can take advantage of Intel EM64T in high quality video and audio processing as well as 3D rendering.
Intel EIST
Intel EIST (Enhanced Intel SpeedStep technology) automatically adjusts Intel 64-bit processor voltage and core frequency according to system performance demand, establishing a self-managed, lower-power consumption, less heat and quieter environment. Combined Intel EIST and ASUS Q-fan technology (adjusts fan speeds according to system loading), this motherboard provides excellently quiet, cool and efficient platform for Intel lovers.
Intel 865GV chipset
Leveraging the Intel 865GV chipset to support P4 CPU on 800MHz FSB, Dual-channel DDR 400 memory, Intel Hyper-Threading Technology, and a full-range of advanced features, P5P800-MX really delivers a full-value, high-performance solution for today's most demanding tasks.
Intel LGA775 Pentium 4 CPU
This motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800MHz FSB, 1 MB L2 cache, Hyper-Threading Technology and core-speeds up to 3.6GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date.
Jul 27, 2009 | ASUS Computers & Internet
Computers & Internet Logo
798 people viewed this question
Top Intel Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
