Televison & Video Logo
n
nikki hudson Posted on Mar 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just bought a pro scan tv ..and i set it up but it keeps saying auto scan why is this
slammit
Level 2:
Habit-Forming:
  • Expert 85 Answers
  • Posted on Mar 18, 2015
slammit
Expert
Level 2:
Habit-Forming:
Answers
85
Questions
Helped
44195
Points
149
It is going through its initial setup and is trying to scan and set your cable channels.
1helpful
New GPX TV is stuck on Auto Scan.....Help
Make sure the antenna is connected properly. If that does not work and it is new. Take it back where you bought it.
We have a prizmo tv and I want to get just local channels. bought a antenna. then what?
You need to look for the settings for the input type. It is usually cable or antenna (digital). Switch to antenna.
Then you need to look for 'auto find' channels, so it can scan to locate and set the channels in your area.
Your TV must have an internal digital TV tuner (ATSC) in order to get new digital broadcasts.
How do I run channel auto scan on Calypso TV
try going to settings ,menu then hit present or auto scan
Display says please run auto channel scan
It sounds like it is not seeing any signal. Do you have the input set for the proper type? Air or Cable
Check your RF connection to ensure you have a signal coming into your television.
When setting up a new TV, it keeps telling me to "Please run channel auto scan." But it also states that if I sellect Cable/satellite, that the tv does not need to run the auto scan. When you...
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
1helpful
I have a cable coming from the wall, and when I hooked it up to my TV Panaconic 42'' viera Just bought the TV today. . the screen is black and keeps saying No signal.... what could the problem be? Just had...
You either set the options incorrectly when running the "First Time Setup" or you skipped the first time setup entirely. Even though the cable works with your older TV, you still need to setup your new TV correctly to receive the cable feed.
The quickest way to do this is run the setup manually from the menu as follows:
1. Turn the TV on
2. Press the "MENU" button on the remote
3. Use the DOWN arrow key to highlight "SETUP" (the arrows are the big ring button around "OK")
4. Press "OK" to enter the SETUP MENU
5. Use the DOWN arrow key to highlight "PROGRAM CHANNEL"
6. Press "OK" to enter the PROGRAM CHANNEL MENU
7. Use the LEFT/RIGHT arrow key to ensure "CABLE" is highlighted
9. Use the DOWN arrow key to highlight "AUTO"
10. Press "OK" to enter the AUTO SCAN MENU
11. Highlight "ALL CHANNELS" using the UP/DOWN arrows
12. Press "OK" to start the AUTO SCAN
The scan may take several minutes to complete.
13. Highlight "APPLY" using the the LEFT/RIGHT arrow keys.
14. Press "OK" - all of the scanned channels will now be saved.
The TV should now return to viewing mode and you should be able to watch cable on your new TV. If the TV does not automatically exit the menu, simply press the "EXIT" key on the remote, next to the MENU button.
Please run through the above steps and if you are still unable to get the cable channels on your new TV, please post back for further assistance.
Regards,
BElectric
2answers
New tv. won't work
Press the input button and select where you have the satellite plugged in.
1helpful
2answers
LTV-40w1 HDC Westinghouse TV
I had the same issue. I just bought this tv. I went to source on the side of the tv pushed the input button til it went to YPbPr1 and the screen came up. My HD cable box is a little old so I'm using that instead of HDMI. But if your using HDMI just keep hitting that button til you see HDMI and it should work.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
