I have a 7 year old Ducane central air unit. everything outside in the actual unit seems to work fine but on the furnace side the fan wont blow the cold air through the ducts. Is it as simple as a reset switch on the fan motor??
No, you probably have a bad evaporative fan motor, capacitor or switching. It usually takes a Pro 1/2 hour to track down such a problem with good training.
If the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
