Question about Hotpoint RFA60 Bottom Freezer Refrigerator
Same Problem ...Drain Hole Freezing up.
I purchased my RFA60 about 6 yrs ago. I Quickly experienced problems re salad freezing in the crisper boxes no matter what the thermostat settings were for either the fridge or freezer compartments. Then shortly after that, the drain hole started getting blocked. Water would not drain and would flood the fridge floor. This would then freeze.
Previous experience regarding the drainage problem with another fridge (Lec type) suggested a blockage with food. I tried to clear suspected food blockage with a length of 6mm O/D plastic tubing but hit what I thought was a 'plastic ledge' similar to the other person with the same problem. I pulled the unit away from the wall and tried to clear from below but again seemed to hit something 'solid'. I thought there must be a ledge or other internal obstruction. In desperation, I used the plastic tube to 'blow' all excess water out of the tube from within the fridge compartment, whilst at the same time mopping it up with a cloth. Once as empty as I could get it. I poured hot water down the hole. Nothing happened. Blew it clear again and repeated. I did this a couple of times then the hot water that I had poured down the drain hole suddenly flowed thro and out into the drain tray mounted on the motor/compressor?
Great I thought. Blockage cleared. Drain working. Not so. Within a week, the same thing happened again. I cured it using the same procedure. There was no food blockage. What I discovered was that the water draining down the hole was freezing, at about 8-10 inches down, and this 'ice plug' was preventing water from draining. This now happens all the time, about every two days after clearing. I can't afford a new fridge freezer just yet so I am constantly having to mop up pools of water, that is, if it hasn't frozen in the fridge compartment, before I then do another hot water 'melt through'.
There are two possible explanations as far as I can see.
a) The insulation around the freezer unit and between the freezer unit and the fridge floor has either failed or was never installed/fitted/laid correctly during manufacture ..... a 'Friday afternoon unit'.
b) The thermostat has failed and the freezer is on max permanently.
I e-mailed Hotpoint and they said they could arrange for an engineer to come out and repair it for a fixed cost of £109. They wouldn't offer any exlanation as to the possible cause of the problem
I suppose that is cheaper than a new fridge freezer but at the moment I don't know what to do.
Posted by paul_steve on
Anonymous
    Sniper:
  • 70 Answers
After facing the same issue (defrosting, cleaning the drain, drain gets blocked again...start again: defrost, etc..) I decided to try to give it one last go:
1. Defrost
2. Clean & rinse the drain (ensure is fully clean and I can pass liquid through the drain).
3. Get a ~30 cm pure copper wire
In my case I took a 3amp power cable, and took the copper wire from one of the cables.
4. Wrap one end of the copper wire around the copper coil at the back of the fridge (where the coil is warmest)
5. Insert the other end of the copper wire in the drain (just above the drip tray). I inserted ~15cm of wire into the drain.
The purpose of these last steps was to ensure there was no "freezing" happening on the drain. The copper effectively will keep the temperature inside the drain above freezing.
Not sure how permanent this might be.. so far at least I'm getting more months than with the previous symptoms treatments ;)
Best of luck!
Posted on Oct 04, 2009
Steve
    New Friend:
I've had the drain hole freezing problem with an RFA60 for a couple of years. I've tried hot water, salt and anti freeze down the hole to unblock it. Also made small heater with a resistor poked up the drain hole powered from a 12V PSU. These all unblocked the frozen tube but would not last long.
Then i thought why not just removed some of the insulation covering the drain tube.
1. Remove the condenser element on the back of the fridge. Be carefull not to bend the copper tubes too much. Support the bottom of the element and lean the top against wall.
2. Locate the drain hole above the compressor.
3. With a sharp knife remove insulation inline with the hole working upwards slowly in case the tube bends. I removed about 6" until i got to the frozen section. The tube is about 1" below the surface. It was a bit deeper at the frozen point - hence the problem i think.
4. Refit the element. Exposing the drain tube and the heat from the element thawed the frozen section in minutes.
No more puddles inside the fridge!!
Why didn't i think of this sooner.
Posted on Mar 22, 2015
4 Related Answers
Anonymous
SOURCE: How can I unblock my Hotpoint FFA70 fridge freezer
I have had the same problem and to solve it I had to turn the appliance off to allow it to defrost as the blockage was caused by the pipe freezing up.
Posted on Sep 25, 2007
John Hall
  • 1218 Answers
SOURCE: Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
Posted on Dec 04, 2009
geoff hunter
  • 4793 Answers
SOURCE: CONDENSATION ON BOTTOM SALAD CRISPER SHELF
cold,damp air,condensates on warm shiny surfaces(bathroom mirror),try putting kitchen towel under the crisper...(why they put crispers on bottom of fridge instead of on top of the cooling coils at the top of the fridge ???)
Posted on Mar 29, 2010
Bruce Denton
  • 273 Answers
SOURCE: The water is no longer going down the drain at the
Greetings,
its most likely ice...take a squeeze bottle or tubing and force water into drain opening. I use a 1/4inch tube and blow into it and then **** some water out and continue this until open...
Posted on Jan 06, 2011
Water in veg crisper freezing
You have a white cover in the back of your fridge it says twin cool on it. Behind that cover is a drain for your defrost cover that is probably frozen and water is leaking through that cover. Wrap a piece of copper wire around the heater and fish it down the drain and it
will fix the problem
May 09, 2014 | Samsung RF265AA Bottom Freezer French Door...
Fridge freezing over
Improve the FixYa experience by voting.
There are two possible causes for you problem:
First. The defrost timer is probably loose internally. Replace it. If it occasionally malfunctions the defrost heater will not work which can be a cause for the evaporator freezing/frosting up.
My advice, replace the timer and you should eliminate the problem(s). This is a do-it-yourself that is in expensive and not difficult to do. You can get everything that you need at a local appliance parts store or check out Siemens parts on their website. CLICK HERE for the Siemens parts website:
Second possibility: The possible cause for the freeze up is that the coil is colder than it should be. There are several potential areas of concern that you might have experienced,
A faulty coil causes items in the crisper drawers to freeze. This is the most common problem I have seen with the Siemens refrigerator.
There may be an air flow problem if the drain assembly has iced up and ice is partially covering the air vent.
If necessary, turn the adjustable feet up or down so they contact the floor squarely.
If you've experienced leaking under your refrigerator, it may be caused by a condensation tube that doesn't drain into a pan or by a clogged freezer drain.
May 13, 2012 | Siemens Refrigerators
Water accumulating in bottom of refrig under crisper drawers but not in drain pan under unit.cannot locate drain line
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 23, 2010 | Kenmore Refrigerators
Water builds up under the crisper drawers and I dont know why?
probably a frozen drain hole in the freezer. a heat probe usually has to be inserted to prevent the drain hole from freezing shut. part # 819043.
Feb 28, 2010 | Whirlpool Refrigerators
Our LG LFX25950SB has been freezing all the food in the refer since we purchased it 3 years ago. Had numerous service calls. They tell us we are leaving the door open, we do not have the correct...
Contact LG @ 1 800-243-0000 and let them know what is going on.
This is a known problem and a fix is availiable.
LG may help you out.
Call M-F for the american call center to answer.
If they wont you can fix it real easy.
Pull out bottom crisper dware.
Look on the back wall.
You will see a dime sized hole.
This hole allows cold air from the freezer to cool the crispers.
Cover the hole with a small piece of duct tape.
This should stop the crispers from freezing.
Also on the right wall of the ref. you will see 1 or 2 egg shapped white covers.
Remove the covers carefully so you dont break it.
You will see a 1" white thermister probe.
Pull the probe out of the insulation and clip it on the egg shaped cover and reinstall the cover.
The thermister tells the computer how cold the ref. is.
Jan 12, 2010 | LG LFX25960 Titanium Bottom Freezer French...
Water dripping from top of fridge then freezing under crisper's
HII Your drain line is plugged remove evaporator cover and get a hair dryer and remove all the ice built up on the drain line its a hole just below the evaporator..show here the hole is on the left side.Good
Jan 05, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is building up in the bottom of my side by side freezer and freezing.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
May 07, 2008 | Freezers
Water freezing in the bottom of the side by side frezzer Frigidaire model FRS26ZSHB0
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Mar 23, 2008 | Refrigerators
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Water beneath the salad bins
check the freezer section if its all frost up at the bottom part. the evaporator is freezing and transfering the coldness at the bottom part that sweats water beneath the salad bins. heater cycle is not working properly...
Feb 12, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint RFA60 Bottom Freezer Refrigerator Logo
2,224 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
