Radio Communications Logo
Posted on Jul 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Police/Fire Scanner I have had my Pro-2018 scanning receiver for about 3 yrs. recently it becomes stuck on a channel with nothing but static and stays there. When my neighbor in the apartment next door was away, I did not have the problem. Now that she has returned so has the static and the scanner stops on a channel and won't work. She tried unplugging her 900 mg hertz earphone equip. that did not help. What can it be that is causing it. She did get a new computer processor about 1 1/2 months ago when this started...could that be it? Or just a coincidence?
Anonymous
Level 2:
Sergeant:
  • Expert 277 Answers
  • Posted on Jul 09, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
277
Questions
0
Helped
77671
Points
755
You can replace it with another one if damaged or repair if faulty,you can check the control panel for settings if interupted,you can check tmy computer on programs to see if the sannner device is found there.
Scanner not picking up local police-Fire freq
Do you still receive NOAA weather frequencies? Sounds like your local agencies have switched from simplex/standard frequency operation to trunking. I suggest you visit www.RadioReference.com to view the latest on active frequencies and systems in your area.
Bill B
4helpful
3answers
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Have a Radio Shack PRO 2018 that stopped working properly,Scans but necver finds anything.adjust squelch and nothing but static so it is not the speaker.PLEASE HELP
Did your local public service switch to a digital system? If so, you cannot receive digital trunking on this radio. Ask at your local Radio Shack store, or a local ham radio operator who can help you out.
Scanner will not move from the programmed Police channel
you may need to play with the squelch. and/also hold down the light/key button until the key goes away but mess with the squelch after you get rid of the lock. you want the squelch as far left without it stopping and making static noise
I have a radio shack pro 96 digital trucking scanner.the other day we finally put up my outside antenna for it.it worked fine all through xmas and new years.the other day turned it on and it would not pick...
The very part of your scanner that makes it a scanner is inop. YOU can find it but IT won't scan. Back to radio shack for warranty before they change their mind.
Need to unlock our radioshack pro 2018 200 channel desktop scanner
Easy to use right out of the box!
Explore preset frequencies used for non-trunked police/fire, aircraft, marine, NOAA weather and more. Just attach the antenna, switch it on and touch one of five buttons. With just two keystrokes, you can store a frequency you find in the 200-channel memory for later scanning or monitoring. You can also search for activity in frequency ranges you specify or program known "action" frequencies on the keyboard.
  • 1-touch search lets you find police/fire, HAM radio, marine and 7 NOAA WX frequencies fast
  • Built-in weather receiver sounds an alarm when your NOAA weather station sends an alert
  • 50-frequency search skip locks out undesired frequencies
  • Programmable by computer (requires Scanner PC Programming Kit #20-048)
Radio Shack Pro Scanner
I know that if you turn your scanner off over a few days you can loose your frequency # or it will lock the channels out. if they or l/o just unlock then. I also know that all police and ect. went digital, you would to have a scanner that is digital. When they changed to digital some for the frequency # have changed. I had to get the new ones and put them in.
[email protected]
2answers
All channels locked out!!!
You might have to reset the scanner, refer to page 70-71 of your manual. If you need a manual go here,,,
http://support.radioshack.com/manuals/ome20-496.pdf
Hope this helps,,, Mechanic
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
