Question about Garmin StreetPilot C330 GPS Receiver
Touch screen is cracked on my garmin c340
Would like to have replacement screen
Posted by tooblack on
  • 6 more comments
  • Anonymous Nov 27, 2007
    I have a c330 with the same problem
  • Anonymous Nov 29, 2007
    MY SCREEN IS ALSO CRACKED.
  • adam15500 Dec 02, 2007
    I have a cracked screen on my c330 also. Part no. from the back of the screen is: TD035STED2 634N1AA0980526.
  • cbis817 Jan 03, 2008
    I have the same problem on my StreetPilot C330.
    My screen is craked and i want a new part.
    Where can i find one. I am in canada
  • Anonymous Jan 07, 2008
    My screen is completely destroyed due to a car accident, and would like to get another one, i'm located in the US.
  • lostinboston Mar 04, 2008
    Question?: I've found people selling the "digitizer" for lcd screens but there are three input options:Narrow strips, wide strips and dots. Does anyone know which type the Garmin c330 is?
  • Sticks53 Sep 09, 2008
    My glass screen cracked on my Garmin C340 Street Pilot GPS during an auto accident. Garmin wants 150+ bucks to repair it. Fortunately my son works for an electronics store and I was able to buy a new one (Nuvi 205W) for a little bit more than that. But I would like to know if I could get a screen and replace it myself so it doesn't go to total waste.
    Tom
    [email protected]
  • Anonymous Mar 24, 2014
    WHEN I TURN IT ON MY GARMIN ASUSG60 IT WOULD ONLY SHOW A WHITE SCREEN , NO OTHER OPERATION, SHOULD I CHANGE THE ->Touch Screen Digitizer replacement,
    oR DO I HAVE TO CHANGE THE ->LCD Display + Touch Screen Replacement
Anonymous
  • 174 Answers
Try ebay.com for replacement lcd. For the C330 search for the following on ebay TD035STED2.
Posted on Jan 10, 2008
  • Anonymous Mar 04, 2008
    The C330 uses the wide strip digitizer, but unless you have the proper equipment (resistance soldering) you will destroy the ribbon cable.
Anonymous
I have a 320 with the same problem. The touch screen is gone. Looks like I'm dead.
Posted on Feb 24, 2008
1 Related Answer
sharcnet
SHARCNET-USA
  • 2130 Answers
SOURCE: touch screen is cracked on my garmin c340
Yes. Please email me at ks3r at sharc dot net and I'll quote you a price to repair it. I have repaired many Nuvi's with this problem. I have references.
- Jim
Posted on Sep 12, 2008
Can the touch screen on my garmin c340 gps be replaced?
Yes, it could be easily replaced. If you want to purchase only touch screen, buy it from :-
http://cgi.ebay.com/GARMIN-C340-C-340-Street-Pilot-Touch-Screen-Digitizer-U-/270622808154?pt=PDA_Accessories&hash=item3f0260585a
If you wanted to replace LCD screen as well, buy it from :-
http://cgi.ebay.com/LCD-Screen-Touch-Digitizer-Garmin-C340-U-/120457660971?pt=PDA_Accessories&hash=item1c0bd60a2b
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 27, 2010 | Garmin StreetPilot c340 GPS Receiver
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
The screen on my Garmin Street Pilot C340 is frozen
I read the manual. There is a reset button underneath the plastic cover surrounding the screen (pry off w/ your thumb) -- push the reset if the power can't be turned off otherwise.
Oct 01, 2009 | Garmin StreetPilot c340 GPS Receiver
My Garmin C340 froze up. can't shut off and touch screen does not
Have you tried a hard reset? Take off the silver trim ring around the screen by hooking a fingernail under it above the screen and lifting it off. There's a reset button at the side of the screen. Press that for a few seconds and it should re-boot the unit.
Jul 20, 2009 | Garmin StreetPilot c340 GPS Receiver
Can my garmin touch screen be repaired it is cracked
it would probably be cheaper to replace the whole unit
Jun 06, 2009 | Garmin StreetPilot c340 GPS Receiver
Frozen touch screen on
hold down the power button when you turn it on until the calabaration screen comes up and that might fix your problem
Nov 01, 2008 | Garmin StreetPilot c340 GPS Receiver
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Jul 21, 2008 | Garmin StreetPilot c340 GPS Receiver
- Jim
Jul 15, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin StreetPilot C330 GPS Receiver Logo
1,129 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
John Egan
John Egan
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
