the power supply internal from the radio is faulty. However test bad contacts, clean contacts very well, test the fuse for bad contacts , corrosion, and clean it. Otherwise , you must go the repair shop Tv for fix it. God bless you
Reboot it by sliding the power button to off and holding it there. If it still doesnt shut down pull the battery out then hold the power button for 10 seconds. Put battery back in and reboot. Also check to make sure that there are not any updates available for your PSP
Hi easy fix take it apart (without the power on :-) ) take out the power supply you will see the 4 pins you slide the power supply upwards the problem is the pins get a wear mark on them clean the pins with some steel wool or if you are good with a soldering iron tin the pins with solder to build them up ONLY IF YOUR GOOD ok!!! put it back together and away you go Good luck
try to use a memory card if it works... be gratefull because the internal memories of any japanese products easy to get corrupted and if u insist to get back ur lost capacity i think u may need to flash it if u find the firmware just make sure that he is the right one :)
