SOURCE: LG washing machine
the Play/Pause button? Check if you have Child Lock on? (Hold the Pre Wash button for three seconds to turn it on or off.
SOURCE: LG Washing Machine All-in-One
Some magic happened today!
I got the thing (wd-12331ad) to dry without having to run a wash first!
Also, I seemed to get it to do a spin only run...
The way to get it to dry :
(for a set time - I've not managed to get any of the auto-dry settings to work)
from machine being off:
> press the power button.
> press the "Dry" button 'til "Time" lights up
>>> press "Dry" again to get the desired duration
> press the spin button 'til the spin speed shows blank/ the RPM light goes out.
> press "Start/Pause"
It will then dry for the number of minutes specified!
Not perfect, I know but that's serious progress from where I was before; having to re-run a wash cycle to get it to dry anything...
Something to note:
- The machine worryingly sounds like it's starting to fill with water when you start the "Just Dry" program which scared me at first. BUT it stops after a second or so (I think it's just cleaning out the detergent tray so it doesn't bake any leftover powder)
For "spin only" from machine being off:
>>> if you press "Start/Pause" now you get a 13 minute 1200 spin cycle
>>> press the spin button again and then "Start/Pause", it seems to drain itself for 1 minute
>>> pressing spin repeatedly, cycles through the spin speeds.
Things I don't know:
- I don't know if you can combine spin and heat.
- I don't know whether the auto-dry programs are available
- I don't know what other programs are available from the "Dry"/"Spin" buttons
...So if anyone does any experimenting, please let us know the results, you never know, we might end up with a half way useful set of instructions! I'm starting to think the machine's not half as bad as it seems when following the manual alone.
Hope that helps.
Will
SOURCE: cant rurn on my my washing machine
Have you tried a simple reset, by unplugging, waiting several minutes and then replugging it in? Is it plugged into a gfi outlet? is the little red button pushed in? It should be. It hasn't flipped a breaker off has it?
SOURCE: I have Model WF-S6607?WF-S6607TC. Washing Machine.
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
SOURCE: Hi, I have an LG washing machine(WD1485RD) and it
There is an air pressure switch that starts and stops certain cycles by measuring the water level. Thanks. Keep
updated for any more query. You can rate this solution and show your
appreciation
It could be that switch is bad, but more likely the timer is failing and not moving forward when the water level switch closes.
If you unplug the washer, remove the water hoses and pull it out you can pull the side of the washer off and check the water level switch with a volt/ohm meter. It's a double switch with a common wire connected to a plastic tube that connects to the side of the drum. If you blow into the plastic hose that goes to it you should hear it click and the ohms on that side of the switch should be zero. Then quit blowing and it should click again and the other side resistance go to zero.
If the switch is good, then the timer is probably failing.also check the drain pump hose if its got bit low then regular then it can also be the other possibility/.
