Question about Generac Electrical Supplies
Generac ix 2000 mod 0057932 start up ok but then stops running
Intstalled new carb. oil level senor new gas spark plug
Posted by lorraine whittemore on
gbob59
  • 3,063 Answers
Possibly blockage in fuel tank or line to carburetor? Fuel filter?
Fuel turn off valve? Generator malfunction that pulls the kill switch?
Owner's manual trouble shooting?
No manual try for owners and repair manual http://www.manualslib.com/
Posted on Mar 17, 2015
Put new gas and new oil in and tried to start. Would stall in few seconds when could start. There is fluid dripping from the filter area
Hi Anonymouse:
I'd be checking to make sure that the correct fluid in the correct amount was added to the correct place.
Start with the oil. Check the dipstick or indicator level. Too much oil will stop the engine. Sometimes gas get accidently put in the oil filler if an inexperienced person is helping with the maintenance.
Gas.......... Make sure that oil was not accidently added to the gas tank. Drain the carb and put fresh gas in the gas tank.
Spark plug.;.... pull and check for fouling. Replace if not really clean. Check for hot blue spark before re-installing.
This should get you back digging up the garden very soon.
May 15, 2015 | Garden
It will run for a while then cut off john Deere
CHECK GAS FOR WATER THEN CHECK MAKE SURE GETTING GAS CHECK PLUG WHAT DO THEY LOOK LIKE WHEN CUTS OFF DOES IT LOOSE SPARK REPLACE COIL IF DOES 80.00 IF NOT GETTING GAS REBUILD CARB ALSO CHECK FUEL FILTER BAD THING ABOUT TRACTORS IF YOU LEAVE THEM OUT SIDE UNCOVERED THEY WILL GET WATER IN GAS ALL OF THEM SO DRAIN GAS OUT PUT IN NEW ALSO DRAIN CARB OUT ALSO CHECK OIL LEVEL IT HAS A OIL CENSOR ON IT THAT REEDS OIL LEVEL IF OIL LEVEL NOT SAFE THEN WILL SHUT IT OFF TRY THIS LET ME NO WHATS HAPPENS THE RED NECK
Sep 01, 2014 | Garden
155c john deere lawn tractor
Take the spark plug out and see what it looks like. If it's dark, sooty or wet smelling like gas, then you have a spark problem. Might need new plugs, a new coil or charging the battery up.
If the spark plug is dry and is a light tannish, brownish color than your problem is not getting gas. If that's the case, take off the fuel supply line to make sure you have gas to the carb. If that is fine, then you might need to take the carb a part to make sure you don't have plugged jets or passageways in the carb itself. If you want to find out quick, you can squirt a little gas into the carb intake and see if the the engine pops off. That will tell you as well.
Good luck
Jul 15, 2013 | Garden
I have a briggs and stratton 13.5 hp power engine that wont start. The engine is almost new, oil level is good and when I remove the spark plug cap and dold it near the top of the plug and pull start it I...
there may be safety switches, but if you are getting a spark, that is not the problem. After you cranked with no start, is the spark plug wet with gas? can you smell gas in the cylinder after pulling the plug? It could be that your carb float/needle valve are stuck closed. Try lightly tapping the side or the carb.
Jun 08, 2017 | Briggs & Stratton Briggs Stratton Intek V...
My Troy Built 5550 generator will not start. I changed the spark plug and oil. The pull cord does not crank the engine. There is a on/off switch, choke and still no spark. The engine is a Briggs &...
The first thing to do is to check and see if it is getting any spark to the plug.
To check for spark, remove the spark plug wire from the spark plug.
Remove the spark plug from the cylinder.
Attach the spark plug wire to the spark plug.
Using insulated tools so you do not get shocked, hold the base of the plug to the bare metal of the engine.
Crank the engine and observe the plug for spark. There should be a bright blue spark jumping the gap of the spark plug.
Is there spark present?
If not, we need to look at the ignition system.
If there is spark, remove the air filter.
While cranking the engine, spray in some gas or carb cleaner - do not use starting fluid.
Will this allow the engine to try and start?
If so, your carburetor is dirty.
As gas gets old, it turns to varnish and clogs up the passageways inside the carburetor, not allowing enough gas to get to the engine.
This condition is cumulative. Every time gas sits, the varnish builds up just a little more, like coats of paint, until eventually gas can not flow. It will not happen overnight, but the symptoms can show up all of a sudden, even while simply stopping to refill with gas.
The use of fuel additives, such as Sta-Bil or Sea Foam will not stop this process from happening. They will greatly slow it down, but the gas will still go bad.
When this happens, either the engine simply will not start, or it will not run without the choke on (this reduces the amount of air getting pulled into the engine, changing the fuel/air mixture), or it will run but surges.
Another issue that varnish in the carb can cause is that the varnish may not allow the float needle to seal properly against the seat, causing the flow of gas to not shut off when the bowl is full. The result will be gas overflowing the carb and running into the cylinder, and possibly out the air intake. If the gas gets into the cylinder, it will seep past the rings and down into the crankcase. This will be evidenced by your oil level being over-full and/or the oil smelling like gas.
The only 2 solutions are to either replace the carburetor or give it a good, thorough cleaning.
When removing the carb, make sure to take a good picture, or make a good drawing of where all springs and linkages are attached. This will make reassembly much easier.
Most people believe that cleaning a carb involves removing the bowl and wiping it out, then spraying some carb cleaner through it.
This is simply insufficient.
To properly clean the carb, you must remove it, disassemble it (making sure to remove all non-metal parts), and soak it in a commercial solvent for several hours. Soaking it overnight is even better.
Then clean all solvent off with a spray type carb cleaner, making sure to get lots of cleaner into every hole and passage there is. Pay special attention to the tiny holes in the bore of the carb, under the throttle plate for the carbs that have these holes. Use lots of cleaner. And make sure to wear safety goggles to avoid getting the over spray into your eyes. There will be over spray.
Dry the carb with low pressure compressed air.
When reassembling the carb, make sure to use a carb kit, when one is available for your carb.
Occasionally, even a good cleaning is not going to be sufficient, and you may end up having to replace the carb anyhow. Be prepared for this.
If spraying in the gas or carb cleaner allows the engine to actually start and run, you will still need to clean the carb - as the idle circuit is most likely restricted.
Oct 26, 2017 | Briggs & Stratton Briggs Stratton 6200...
Will not start
If you have a spark plug wrench take out the spark plug look at it if it is all wet engine is flooded with gas,dry it and clean it if it is dry its not getting gas, try putting in a new spark plug. is there gas in tank , is switch on, is gas turned off, is the tank full, is the gas old and stinky? has the tiller sat for months carb may be plugged check ,engine oil level, try a little shot of engine starting fluid or gas sprayed into carb needle valve in carb may be pluged, float in carb may be stuck. tap on carburetor good luck
Jan 31, 2011 | Troy-Bilt Garden
Yard machine lawn mower won't start
Several questions here...
1. Is the oil serviced to the full mark?
The oil level sensor can cause a no spark condition because it grounds the ignition.
2. Is there spark at the spark plug? You can remove the spark plug and test for spark but if the plug is internally grounded it will show spark when removed but if it is installed it can still be defective. (Spark Plugs are cheap replace it)
3. Is the handle safety cable loose even when depressed? A bad safety cable or an improper cable adjustment can also cause a lack of spark.
4. Do you note gas on the spark plug or is it very dry? If the spark plug is dry try adding a splash of gas into the cylinder via the spark plug hole and see if you get a temporary / momentary start. If you do then you have either a fuel supply or carb problem.
Make sure the fuel selector is in the ON position.
5. If you suspect a fuel problem disconnect the tank feed line to the carb and see if there is fuel flow from the tank, No fuel flow no start.... then problem in the gas tank or supply line.
I will post this as a solution but will watch for any responses and continue to assist you if needed.
Thanks for using FixYa.
Kelly
Jun 11, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
545 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
JOHN LAPIER
Bill Johnson
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
