Question about RCA Televison & Video
My rca remote turns the toshiba tv on but it dont change channels
My Eva remote turns my Toshiba tv on but won't change channels
richie46
    Top Expert:
  • RCA Master
  • 12,962 Answers
U are using an RCA remote with Toshiba tv. You are lucky that it even turns the set on. You have different remote frequencies involved and need to use the Tosiba remote or a universal remote that will operate volume, channels and power.
Posted on Mar 17, 2015
I have a toshiba tv 39al900a which was won in a raffle. When you turn it on it says please scan channels.t.
The first step is to make sure you have good batteries in the remote. The ones included tends to be cheap and you have no idea how old they are.
Here is the manual, page 12 explains how to use the remote and the next few pages cover the initial setup and scanning of channels.
http://www.mytoshiba.com.au/file/download/resource/file/23089/39al900a%20owner's%20manual.pdf
If the remote is still not working, get a universal remote to replace it. This link gets you the codes to program the universal to work with your TV. http://codesforuniversalremotes.com/universal-remote-control-codes-toshiba-tvs/
Feb 05, 2017 | Toshiba Televison & Video
I tried to program the TV 125 channels but only channel 3 is viewable
If it's a universal remote, you should find another one.
If original, it's not working
Jun 02, 2015 | Toshiba Televison & Video
My Toshiba 36AF43 won't get any channels with converter box or anntenna
  • Connect the antenna to the antenna input of the converter
  • Connect the R-W-Y outputs of the converter to the corresponding inputs on the rear of your Toshiba TV.
  • Turn both units on. You should see a converter menu displayed on the TV screen.
  • Select channel scan on the converter. You should see a progress bar displayed on the TV as channels are detected.
  • Scanning should finish by displaying one of the scanned channels.
Dec 08, 2017 | Toshiba 36AF43 36" TV
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
I have a Toshiba TV/VCR/DVD combo, remote WC-FN2. I can turn the TV on,change volume but can not change channels. Help! Thanks,
Some tv remotes will do this if the TV is programmed to skip all but one channel (or the last scan for channels had only one active channel - like a tv connected to a set top box (3,4,60)).
See if you can navigate to other channels by typing in a channel number. Also check if the Tuner is the current source of the video signal by pressing the Source or Input button. If you have a menu button on the TV or the remote, try rescanning channels or editing the channel list.
I hope this helps.
Sep 23, 2010 | Computers & Internet
How to get TV/video mode without remote
some tv do that changing the channels.
in the control panels in the tv where r the buttons for change channel there must be video button, push it and there you go.
Good Luck
Jan 12, 2009 | Toshiba 14AF44 14" TV
Toshiba Remote #CT-847
where can I get the manual for a Toshiba ct-847 remote
Dec 06, 2008 | Toshiba Televison & Video
Remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Oct 02, 2007 | Toshiba 20AF44 20" TV
Televison & Video Logo
90 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
