Question about Dewalt 18v Xrp Battery Dc9096
Dewalt 18v XRP Problem Powerline
I have one XRP battery that shows Problem Powerline in all three of my charges. All my other batteries charge fine except this one.
Posted by Ted Osborne on
Dewalt Customer Service
  • Official Brand Answer
  • 14 Answers
It sounds like you have a defective battery. I would suggest contacting one of our Factory Service Center's to see if your battery is still within warranty. Please see the link provided. You can also give as a call at 1-800-4DEWALT. DEWALT com
Posted on Mar 20, 2015
  • Dewalt Customer Service
"Problem Powerline" flash code appears when I try to charge a particular XRP battery in any of my three charges yet all my other batteries charge fine.
Mar 17, 2015 | Dewalt dc9096 xrp battery 18v
Dewalt charger normal flashing with no battery connected
please clear the contact of the battery and charger, charge the battery again. If still no help, please use a good battery to see if it is the problem of the Dewalt DC920KA battery or the charger.
Jul 11, 2014 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
DEWALT charger flashing with no battery to charge, doesn't appear to be charging batteries either.
This sounds like your charger will most likely will need to be replaced, in this day in time most charger are throw aways.
Jul 11, 2014 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Does battry have to cool down before charging?Dewalt DC920KA Heavy Duty Xrp 18V Cordless
Yes, when a battery is being used for a long time, you need to let it cool down and take it to charged. Although there is many fast charger now, but in order to protect the battery, I recommend you to buy a second battery for replace.
And, if you do not know where to find the right one? Here is some suggestion for your Dewalt DC920KA Battery
Jun 17, 2014 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I have 32 dewalt 18v dc9096 batteries and 1d dewalt 18v dc9099 battery. I tried charging them and back to back they all start off charging fine then charging light speeds up as to suggest their all bad. ...
May read instructions and see if charger is compatible of charging the two types of batteries you are charging ,,,,I have 32 dewalt 18v dc9096 batteries and 1d dewalt 18v dc9099 battery
Sep 27, 2017 | Drills
My dewalt 18v xrp battery wont take a charge
Depending on how old or more to the point how many times you have already charged the battery, it may be worn out. All rechargeable batteries do reach a point where they won't charge up anymore. If you have fully discharged the battery and tried to fully charge it up again and it won't take a charge or only lasts a few minutes on a charge it may be time to recycle it and buy a new one.
Aug 22, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Do you have to charge new batteries before use? 18v xrp
normally they carry little bit of charge but its alwys good to charge b4 u use them .. good way to check the battery charge is either there will be a battery meter on the battery like 5 leds on it or alternatively u do to bios of a laptop and check for battery meter
cheers
Dec 09, 2009 | Dewalt 18v 1/2" Compact Drill/driver Kit...
Holding battery charge on 12v DeWalt batteries
Are batteries for the dewalt cordless drill interchangeable? Will an 18 volt battery fit in a 12 volt drill?
Aug 27, 2008 | Dewalt 12V XRP Battery Pack
Hamer drill xrp
if the battery are less than a yr old should be a warranty
if drill DC920 or DC925 they are on recall for switch. may be co'z the battery to die. have them check at ur nearest service center.
Jul 13, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt 18v Xrp Battery Dc9096 Logo
411 people viewed this question
Top Dewalt Electrical Supplies Experts
efs_perpends
efs_perpends
John Trevino
Marvin
Marvin
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
