Question about Teac DC-D2831 CD Shelf System
Cd drawer won't open on my TEAC DC-D2831
The cd player is jammed shut and will not open and the cassette won't play
3 Suggested Answers
6ya staff
SOURCE:
mattozan
Matt Jurach
  • 555 Answers
SOURCE: I have a TEAC Stereo
Try resetting it by pulling the power cord and then replugging the unit.
Posted on Jul 23, 2008
Anonymous
SOURCE: How do I get my Teac DC-D2831 CD Shelf system to
I was having the same problem, I read my users manual and found that there is a time button on the front of the unit itself. My husband must have pressed ithe last time he used it. Works fine now.
Posted on Apr 29, 2010
The system just shuts off after the word "eject" appears on the screen.
It is likely mechanical disassembly will be required to extract the damaged cassette in the B drive and the jammed cassette in the A drive. The electromechanical A-B switching mechanism may have failed because of age aor failure of synchronization. The tapes, if very thin or stretched could be a contributing factor.
Feb 26, 2014 | Sony DHC-MDX10 Shelf System
Marantz PMD 350 CD player/Cassette deck
Well if you want to DIY you should open the coves, spay some oil on the mechanics and ensure they are running smoothly, if you spray grease on lens you will damage it, be careful.
Jun 01, 2008 | Audio Players & Recorders
How do I get the cassette adapter to play CD's out of my 1999 Ford Taurus? And can you use one anyway?
The adapters have a tendency to jam in the cassette player slot. Some cautious wiggling may release it.
Jan 16, 2018 | Ford Cars & Trucks
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
My cassetteplayeris broke but the front panel says tape unpluged it radio won't play pluged it back in few days later tharadio came back on.going down the road it swithched from radio playing back to tape...
the cage mechanism of the cassete is dropping causing it to shut the radio off ,only solution is to remove the radio and open case then jam the cage into the no casette position with a piece of wood or a folded up cardboard ,i think this will cure the problem
Feb 15, 2011 | Car Audio & Video
I have tried to record from Tape to CD with No result. I have followed the instructions for this task, to the letter and still nothing on CD.
First make sure yoou are using correct cds. You need CDR Audio discs not blank pc media type (Yes they are different). Once you have the disc type right, make sure you are finalizing the disc as they will not play in other machines until u do this
Oct 30, 2010 | Electro Brand Nostalgic Stereo CD Music...
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
Tape witll not play
your tape player may be jammed up and not playing your cass.
Jul 04, 2007 | Sony Walkman WM-FS593 Personal Cassette...
Teac DC-D2831 CD Shelf System Logo
232 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
