Question about Microsoft Xbox 360 Console
Xbox 360 i got my xbox for christmas last year and yesterday three red light started to flash on the console and the game crashed, since then nothing will load and the red light keep flashing HELP????????
Posted by RYANWHELAN on
Anonymous
Unfortunately this is a very touchy situation. There is one home method for curing this problem.
1). Wrap your Xbox 360 Console COMPLETELY with a towel, so you can only see the power button, and the three flashing red lights.
2). Power on your console.
3). Leave for 30-45 minutes.
4). Power off the console.
5). Unwrap the towel from the console.
6). Power on.
**Problem Solved** If not continue reading.
After that you are unfortunately forced to call the dreaded Microsoft Customer Support Line
1-800-4-MY-XBOX
1-800-469-9269
And ask to create a repair order, they will send you a Purolator (or FedEx) shipping box. You have to send your console to them, they will repair it and have it to you within (2-3 business weeks).
Posted on Nov 13, 2007
Desk top not coming up red light flashing on front
hi , the only thing ull have to do is take it in , it shows red light it has basically crashed . It happens to all x box 360 at least once a year .Sometimes twice depending on usage , dont think it cost anything ,just postage to xbox factor and it will be returned .Cll in to ur nearest gaming centre and the will sort it,or google xbox for details hope i answered ur question
Nov 06, 2010 | Microsoft Xbox 360 Console
Three red lights on my xbox and keeps crashing
Sorry, but this is a hardware failure Your xbox will need to be serviced by Microsoft.
You can call 1-800-4MY-XBOX to start the repair process with Microsoft. good luck
Jun 17, 2010 | Microsoft Xbox 360 Console
Xbox 360 Console: my xboxs 360 has three red lights flashing...
Hi Sir
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Please Rate
May 17, 2010 | Microsoft Xbox 360 Console
3 red lights box under 3 years old
RED LIGHT OF DEATH!
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 motherboard or power supply.You can test power supply with a voltmeter from power supply wires to the connections on the motherboard. If no power or low power, the supply is bad. If there is plenty of power, then motherboard could have bad capacitor or chipset on it causing the problems. You can test those with an ohmmeter to see which component is not the same.
Nov 23, 2009 | Microsoft Xbox 360 Console
Well when I turn on my xbox 360 the third part flashes red.
hello.
CAUSE The three flashing red lights may indicate that your Xbox 360 console has experienced a hardware failure. Please read the letter that discusses warranty changes for three flashing red light hardware failures.
MORE INFORMATION
If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue:
1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles:
906101 Xbox 360: The power supply light is red 906102 Xbox 360: The power supply light is orange 906103 Xbox 360: The power supply light is not illuminated
2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again. If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support, and then click Console Repair in the upper-right section of the Web page.
Note: The online console repair service is currently not available in all countries or regions.
If you would rather contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact for information about how to do this.
APPLIES TO
* Microsoft XBox 360 Video Game System
* Microsoft Xbox 360 Hard Drive (20 GB)
* Microsoft Xbox
Apr 27, 2009 | Microsoft Xbox 360 Console
3 red lights on console
try looking around support.xbox.com
Dec 29, 2008 | Microsoft Xbox 360 Console
RED RING WHEN TURNED ON OFF FOR A WEEK
SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Nov 26, 2008 | Microsoft Xbox 360 Console
Flashing red ring on x box 360 console
3 Blinking red lights often means that your Xbox 360 has suffered from hardware failure.
4 Blinking red lights means that your Audio / Video cable is not correctly connected (it's the colorful one; Red, white, yellow; green, blue, red if Component)
If it IS just three lights, and you bought your xbox 360 under three years ago, call 1-800-4MY-XBOX
Jul 18, 2008 | Video Game Consoles & Games
Red ring flashing
If you bought your Xbox 360 within the last three years it is still under warranty for the flashing red ring error.
Go here https://service.xbox.com/
Register your Xbox and request repair service, you will not have to pay for anything and get a new 360.
Apr 17, 2008 | Nintendo Game Boy Advance Console
Microsoft Xbox 360 Console Logo
94 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
