Question about Comcast XFINITY
Need to program Comcast remote to run Craig TV
johnny rebel
    Top Expert:
  • 10,875 Answers
Programing my xfinity remote
About 13,200 results (0.79 seconds) Search Results
    Can't program Comcast remote to Element TV - Comcast Help and ...
    forums.xfinity.com/.../XfinityTV...program-Comcast-remote...Element-T...
    Jun 6, 2011 - I have an Element 47" Class LCD 1080p 60Hz HDTV, ELGFT471. My remote is the Comcast Universal Remote - Red OK/Select Button.
    Comcast - what programing code to use with element tv find ...
    https://www.directly.com/.../comcast-what-programing-code-to-use-with-...
    what programing code to use with element tv find a code does not work ... Mymistake. ... Also found that Element has a remote update for some televisions.Missing: panel
    Element Tv Comcast Remote (Tut) - YouTube
    ? 3:19
    https://www.youtube.com/watch?v=ZDBr-hZN2AI
    Jan 20, 2010 - Uploaded by TopBreakX3
    The tut should be in your comcast remote paper help thing but heres the code if u cant see ... cant see clearly ( 10178 ) This is a vid on how to setup your comcast remote for your element lcd tv. ... Who cares program the Comcast remote already ... this was awesome,,,,my sisters tv is on the go now,,,thanx .Missing: panel
    Comcast Remote Codes for TV - Easy PC Tutorials
    www.easypctutorials.com > Comcast
Jan 27, 2016 | Element Electronics Televison & Video
How do I find a comcast remote code?
use universal remote pairing feature on tv .
Sep 04, 2014 | Craig Electronics CHT912 Bluetooth TV...
Remote control
Find the remote codes, then program the remote with the printed instructions. Or; Visit the website below. http://tv.manualsonline.com/support/craig/
Apr 01, 2014 | Craig Televison & Video
The TV cannot be set nup with the Comcast remote...even they have tried...the volume on the TV is terrible!!!
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device/
Mar 04, 2018 | Televison & Video
I need to program my cable box
The real problem with the Comcast remote is that there is no other brand, it's not like a Sony remote that's relabeled or anything. Fortunately, Google helps again, and it turns out Comcast has a page online about programming the Comcast remote control.
comcast_remote.jpgComcast 3-in-1 remote control To program the remote to work with your Sony TV, you need to take the following steps:
  1. Find the code or codes for your TV from Comcast's list [PDF]
  2. Turn your TV on
  3. On the remote, press and release the TV key on the very top of the remote.
  4. Press and hold the Setup key, until the "TV" key flashes twice, then release the "Setup" key.
  5. Using the number pad, enter in the first 4-digit code found next to your television brand on the chart. If you do this correctly the "TV" key will flash twice. Now it's programmed!
  6. Now point the remote at your TV and press the Power key. If the TV turns off, you're golden. If not, try again with the next code on the list.
Jun 01, 2010 | Symphonic SC3919 Combo
Looking for the codes to set remote for Comcast cable
comcast remote will not turn on or off my RCA LCD Flat Panel HDTV L42FHD37R
Dec 07, 2009 | Televison & Video
13" superscan remote with comcast
all cable networks have a manual that shows how to us the R/C [remote control] to SCAN ALL model #s of tvs for all the codes. If you don't have the manual, call Comsast Cable & they should be able to help you.
Note: sometimes a cable network cannot control all TV's R/C because some companies BUY off excess tvs and place their name on the brand.You could be buying Zenith, Sony, RCA !! guts with E.I. "superscan" brand on it.
P.S. sometimes the code is just enought to turn the tv on, raise\lower volume.
Jun 24, 2008 | Televison & Video
Comcast XFINITY Logo
258 people viewed this question
Top Comcast Televison & Video Experts
SPAMKILLER
Tom Chichester
Are you a Comcast Televison and Video Expert? Answer questions, earn points and help others
