Question about Spirit Fitness Z100 Treadmill
Where can buy lube for a z100 spirit treadmill?
What type of lubrication do I buy/use for the spirit fitness z100 treadmill?
gbob59
  • 3,063 Answers
Owner's manual
no manual try: http://www.manualslib.com/
Posted on Mar 16, 2015
My Z100 Tredmill screen will not reset or respond when any button is pushed on the console. The fuse on the board is good. The outlet is properly grounded. Need Help
Safety key is installed? No response from key presses usually indicates a "halt"state for the upper control "brains" like when the safety key is pulled. You can also try jatinah electronics for further help.
Feb 01, 2015 | Spirit Fitness Z100 Treadmill
Lubricating walking belt
Video about How to Wax a Treadmill Using Powder Wax
How to Wax Treadmill Using Powder Wax Video
How To Re-Wax a Wood Deck for a Trotter Treadmill
How To Re Wax Wood Trotter Treadmill Deck
Video of How to Lubricate a Treadmill using Liquid Lube
How to Lubricate Treadmill Using Liquid Lube Video
Apr 02, 2014 | Exercise & Fitness
Treadmill
Sorry, but the description does not indicate what type of machine you are looking to purchase.
Assuming it is a trealmill? Not all machines use belts which need to be lubed any more. AFG (Advanced Fitness Group) uses a belt deck combo which is pre-impregnated with lube for the estimated life of the belt. Landice does not suggest any lube for their standard home use treamills but does make Slip Coat if an additional application were needed.
Traditionally, you loosen the tension on the rear roller so you can access the laminated deck, on which the belt slides on top of. Specific to each brand or model of belt, you will apply either a wax or silicone lubricant. They are usually supplied in a single "dose" or application volume. Apply the lubricant to the deck, retension the belt and start the machine at a slow pace to evenly distribute the lube.
If you were referencing an ellitical, most manufacturers just want the track or beam to remain clean. Cleaning with a light solvent with usually remove any built up. I have found White Lightning (make) Clean Ride (model) wax based lubricant can resolve any noise a good cleaning cannot fix.
Jan 08, 2013 | Exercise & Fitness
I have a ET-388 threadmill. however when i walk or run on the machine the sound is very heavy. can you tell me what is wrong of is it normal?
hi,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck. Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video. ok
Jul 14, 2011 | Spirit Esprit by ET-8 Folding Treadmill
How do i oil my treadmill and with what
Always check the owner's manual before choosing lubricants for any treadmill. Treadmills could be designed to use either wax-based or silicone-based belt lube. Low maintenance treadmills could even be damaged by unnecessary lubrication. Watch the following video to know how to iol your treadmill.
ok
Mar 08, 2011 | Proform XP 580 Trainer Treadmill
Screen states Lube Belt , do not have user Manual , Where are lubrication points and what type "lube" can I use ?
hi,
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
Dec 26, 2010 | Horizon T91 Treadmill
It is saying schedule maintance see owners manual
The manual should point out specifics but this is usually a message that is generated by the miles on the mill. Most important maintenance on a treadmill is keeping belt lubed. We also vac under the hood( motor area) to get out dust, lent and debris. and lube elevation mech. Check owners manual for type of belt lubricant.
Nov 16, 2009 | Startrac Fitness Products Lamar L1400...
Spirit Fitness Z100 Treadmill Logo
209 people viewed this question
Top Spirit Exercise & Fitness Experts
gbob59
Marvin
Marvin
john h
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
