Question about iPhone Apps
I need this word unscrambled it's related to St' Patricks day? reldanl
How do I get same day clearance on cheque deposited into a Stgeorge Bank account?
you need to notify the bank for their policies we don't have access to personal accounts
Aug 13, 2016 | St.George Bank StGeorge Banking App
How can i start a cosplay?
to meet the standards on this exclusive get together, My spouse and i followed the actual convention's unofficial, although strongly suggested type of st patricks costume
Aug 19, 2013 | Toys
I dont know how to change the time on my decathlon geonaute watch
I nearly went crazy pushing buttons, but finally got the right combination. From the normal Time Display (as you would normally use the watch, no need to push any buttons) Push and Hold for a few seconds the Lap/Reset Button. The "Set" Mode will become active. Release the Lap/Reset button when Set appears in the Display. Notice in the Display a small Arrow that points to a button, either the ST/STP or Mode Button. (Initially it will be the ST/STP Button). When you depress the button to which the arrow points, the Field Flashing in the display will be set (For ST/STP) or Changed to the next Field (When the Arrow Points to the Mode Button). Simply toggle through the fields (using the Mode Button) and set (using the ST/STP Button) as needed. You will also be offered the ability to set the Month, Date, Day, 12/24 HR, and a M-D (It stands for Month - Date, in Europe it's more common to display as Date - Month). I did not change this field since by default on my watch it displayed M - D first. The setting cycle will be finished off when you have set the various fields by again pushing the Lap/Reset Button. Not related to setting the watch, but possibly useful, the Watch will completely reset if all the buttons are pushed at the same time, including pushing the Display Light (or in the case of this watch, the illumination used for the Display Characters). Hope this helps, it worked for me.
Nov 01, 2011 | Watches
How do i set the time and date on my watch?
This is direct link to all ARMITRON watch manuals/instructions: http://www.armitron.com/watch_instructions.asp
or
You can also try with this approach. This is for Armitron WR 330,but i believe this could also help you.
The following labels are on the inner ring of the watch; I've given their positions relative to where numbers would be on the face of an analog watch.
"ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
To set the time, date, and day of week:
Press and hold in the "MODE" button until the display starts flashing. (This is the alarm time.)
Press the "MODE" button again; the seconds begin flashing. Press "ADJ" to set them to zero.
Press the ""ST/STP" button to change what you want to set. The options appear in this order each time you press the "ST/STP" button: minutes, hour, month, day, day of week.
Use the "ADJ" button to change the value of the setting.
Touch "MODE" to save the settings and return to time mode.
Thanks for using Fixya. Please rate the solution.
Nov 06, 2010 | Armitron 165 watch
How to set an Armitron WR330 Watch
he following labels are on the inner ring of the watch; I've given their positions relative to where numbers would be on the face of an analog watch. "ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
The website listed below has many instruction sheets, but does NOT have instructions for this watch as of 25 December 2008.
Check:
http://www.armitron.com/WatchInstructions.html
Mar 15, 2009 | Watches
iPhone Apps Logo
268 people viewed this question
Top Apps Experts
Marvin
Marvin
Bill Boyd
ray gallant
Are you an App Expert? Answer questions, earn points and help others
