You need to be using the TV's remote, not the Time Warner remote. You are reading the TV's manual to set it's remote, not the Time Warner remote. If you want the Time Warner remote to operate the TV, you will need to find the instructions that the Time Warner box/receiver provides and enter the TV's code.
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process.
Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com)
Using Pre-Programmed 3-digit Code method
-Turn on soundbar
- Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit.
- Point remote control toward the soundbar and enter code (447 for Boston Acoustics)
- Press the device button again to store the code.
The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me.
Step 2: Program your remote from the Boston Soundbar.
- Press the power button and the volume up button simultaneously until the indicator light flashes orange.
Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming.
- Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange.
- While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed.
- Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote.
Good luck, I hope this helps. -Deidre.
For Time Warner Cable TV Remote Codes for DAEWOO-TV's - •Go to Time Warner Cable web site to PROGRAM REMOTE -- Site URL is http://www.timewarnercable.com/en/residential-home/support/pyr.html•Then select TW Cable remote model. •Under Control a Device -- first select type of device (TV) •Then select Brand Name (DAEWOO). TW Cable lists several codes to cover different models. •Choose a code and input into remote to see which code works. Try all codes. There were several codes to choose from and to try inputting into my TW Cable remote. Finally, the next to last code worked on my TW Cable remote -The Atlas OCAP 5-Device Remote Control by Universal Electronics. The code for this remote for Daewoo TV Model DTQ-13P2FC is 1661. Hope this helps. Otherwise, try checking the site of your cable or satellite provider & you should be able to get their add device codes for free.
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
go to the time warner remote device web site. also you can find many programming codes at sites like howard forums, scribd.com such. Also try the lifestyle web site. these codes are usually free to look up.
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box where can i find how to program remote that comes with time warner cable
