Cooktops Logo
A
Anonymous Posted on Mar 16, 2015
Two of gas burners will not light - Cooktops
Douglas Jensen
Level 3:
  • Master 494 Answers
  • Posted on Mar 19, 2015
Douglas Jensen
Master
Level 3:
Answers
494
Questions
0
Helped
205746
Points
1354
Assuming you have electronic ignition on your stovetop, you may have spilled food onto the burner which has clogged the holes needed to get gas to the spark ignitor. Clean the holes (or slits) and dry them and try again. If they are not dirty, check to make sure you have a spark at each burner. If you have manual pilots, there could be many other problems, like the pilot is not lit, dirty vertical holes (on the burner side) at the pilot tunnel or tunnel is not positioned properly.
On a 4 burner Gas cooktop - all 4 burners get gas but why does the igniter only work with the front 2?
Usually that's caused by clogged holes in the burners. I clean it out using a toothpick.
2answers
So when I try to light one burner - it lights up. After 20-30 seconds, there is stlll a clicking sound then the burner goes off. I cannot figure this out, can anyone help? Really appreciate it. Thanks
It probably has a flame failure device..
This is to cut off the gas if the flame goes out..
When you light the burner, the flame heats a sensor which keeps the gas on, if this is faulty, the gas will go out.
I have the drop in Jade 5 burner cooktop. for the first time, I noticed a significant gas smell when I light any of the burners. we cant figure out the problem since the cootkop is functioning fine, but...
All gas burners will put off a gas Oder when lit, if you go away for a while and come back home and smell gas, you should turn off the gas and call the gas company
2 burners wont ignite
Hello there:
A burner doesn't work The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite. The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or call a qualified appliance repair technician.
1helpful
2answers
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Gas burners won't light
Make sure the little tiny flash holes are open. They allow a little bit of gas to seep out so the igniter can light the burner. If you can light the burners with a match, check those holes.
If yours are the "sealed" type burners, make sure they are not a half a turn out (180° around)
Jan 10, 2010 • GE Cooktops
7helpful
Cooktop igniter sparks but gas will not light
hello there. i can help you.
Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
1helpful
2answers
Burner won't light
Clean the gas nozzle w/small wire are located at the back of the gas cook top /shut off the gas clean small gas nozzle clog / w moisture /rust dust and any foreing material.
2helpful
High performance burner slow to light
Replace that ignitor on that burner only. Not drawing enough amps to spark properly.
Top Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
