T
Thonde Muchabayiwa Posted on Mar 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I receive an error "failure to print pdf file" on a ricoh mp2553, what can I do?
When printing pdf file its not printing the file only word document are able to be printed
quennie732
Level 2:
  • Ricoh Expert 422 Answers
  • Posted on Mar 19, 2015
quennie732
Ricoh Expert
Level 2:
Answers
422
Questions
0
Helped
236037
Points
775
Install another print driver.- Carl
NoName Jack
Level 3:
  • Ricoh Master 1,150 Answers
  • Posted on Mar 20, 2015
NoName Jack
Ricoh Master
Level 3:
Answers
1150
Questions
Helped
232692
Points
4657
See various websites about PDP Printing problems
Like
http://www.iceni.com/blog/problems-printing-pdf-files-in-windows-7/
Ricoh c6501 sp error coad sc 925 solution
SC925 B Net File function error *GW The NetFile file management on the HDD cannot be used, or a NetFile management file is corrupted and operation cannot continue. The HDDs are defective and they cannot be debugged or partitioned, so the Scan Router functions (delivery of received faxes, document capture, etc.), Web services, and other network functions cannot be used.
HDD status codes are displayed below the SC code: • Refer to the four procedures below (Recovery from SC 925). Here is a list of HDD status codes:
Display Meaning (-1) HDD not connected (-2) HDD not ready (-3) No label (-4) Partition type incorrect (-5) Error returned during label read or check (-6) Error returned during label read or check (-7) "filesystem" repair failed (-8) "filesystem" mount failed (-9) Drive does not answer command (-10) Internal kernel error (-11) Size of drive is too small (-12) Specified partition does not exist (-13) Device file does not exist
Procedure 1
If the machine shows SC codes for HDD errors (SC860 to SC865) with SC 925, do the recovery procedures for SC860 to SC865.
Procedure 2
  1. If the machine does not show one of the five HDD errors (SC860 to SC865), turn the machine power off and on.
  2. If this is not the solution for the problem, then initialize the NetFile partition on the HDD with SP5832-11 (HDD Formatting - Ridoc I/F).
    NetFiles: These are jobs printed from the document server using a PC and DeskTopBinder. Before you initialize the NetFile partition on the HDD, tell the customer:
    • Received faxes on the delivery server will be erased
    • All captured documents will be erased
    • DeskTopBinder/Print Job Manager/Desk Top Editor job history will be erased
    • Documents on the document server, and scanned documents, will not be erased.
    • The first time that the network gets access to the machine, the management information must be configured again (this will use a lot of time).
  3. Before you initialize the Netfile partition with SP5832-11, do these steps:
  4. Go into the User Tools mode and do "Delivery Settings" to print all received fax documents that are scheduled for delivery. Then erase them.
  5. In the User Tools mode, do Document Management> Batch Delete Transfer Documents.
  6. Do SP5832-11, then turn the machine power off and on.
Procedure 3
  1. If "Procedure 2" is not the solution for the problem, do SP5832-1 (HDD Formatting - All)
  2. Cycle the machine off/on.
In the middle of the page there is no printno color, nothing, only right and left it works !!!???Thanks to every Helper out there !
dont print pdf files,convert them or turn them into a png file,use the snipping tool,it is like doing a screen shot but more controllable
Ricoh Aficio MP C3300
Go into the print driver and the machine settings and make sure the paper size and direction are all in agreement with each out and the paper in the tray itself. If screen icons do not agree with the size and direction of the paper in the tray you will have a lot of weird problems.
1helpful
How to scan in pdf format using the Ricoh mp 2500
You need to install a PDF printer driver on your computerfirst. There are quite a few freeware PDF writer programs on the Internet youcan download one such as CutePDF.
From the computer scan your document then click on File - Print and select the PDF writer as theprinter device. Then name and save the PDF file. To download Cutepdf PDF printer driver (freeware) click onthis link :- http://www.cutepdf.com/
5helpful
4answers
Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly...
Help with PDF Documents Some documents on Maine.gov are provided in PDF format. In order to view or print PDF documents, you need the free Adobe Reader. Generally, you will find an alternative format is also provided for the document, such as Microsoft Word, HTML, or plain text. If you cannot access a document in PDF format and there is no alternative version, please contact the agency or contact the Maine.gov webmaster for assistance.
Adobe PDF-to-HTML Online Conversion Tool
We've provided solutions for some common PDF issues below.
General Tips: Problem 1: Blank Page in Browser You have selected to download a file and you receive a blank page with a "Done" message at the bottom of the browser. This may be because you do not have enough space in your temporary internet file folder to complete the download.
Solution: Internet Explorer: Tools> Internet Options> Temporary Internet Files> select Delete Files
Netscape: Edit> Preferences> Under Category on the left Advanced> Cache> click Clear Memory Cache
Problem 2: Blank Page "%PDF" You received an error message containing "% PDF" or you have received a blank page while trying to download. This is due to a problem with your web browser not opening .pdf documents correctly.
Solution: Adobe Acrobat Reader 5.0: Edit> Preferences> General> Options> Web Browser Options> make sure the Display PDF in Browser box is not checked.
Adobe Acrobat Reader 6.0 and newer: Edit > Preferences > Internet > make sure the Display PDF in Browser box is not checked.
Problem 3: "Error Locating Object Handler" You receive an error message that says "Error Locating Object Handler" while trying to download a document. This is because there is a dependency with a plug-in for Adobe Acrobat while using Internet Explorer.
Solution: Please go to the following website for detailed instructions: http://support.microsoft.com/default.aspx?scid=kb;EN-US;q262213
Problem 4: Unable to Print You have successfully downloaded the pdf, can view it on your computer screen but are unable to print. This is due to a post script error with your printer.
Solution: In any Acrobat Reader program: File > Print > check the Print As Image box > OK
Problem 5: "Adobe Reader could not open file" You received the error message "Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly decoded).
Solution: Adobe Acrobat Reader 6.0: Edit> Preferences> Internet> make sure the Display PDF in Browser box is not checked.
The printer is printing a line down one side of every page it prints
Are you printing a scan or a fax?
If so, you may want to scan the file as a ".PDF" file. This vertical line is sometimes an artifact of receiving a fax.
Don
Problem getting the Ricoh Aficio CL12000N Printer to print files
Hi, Sorry you are having problems,
Ok, well, that sounds to me like you have a new version of Adobe Acrobat. And, well, the new version of Acrobat works with more and more options and bigger and more complex documents.... And.... well, your G3 and the Ricoh printer just can't handle these files.
So, what is the solution other than buying a new computer and a new printer, which would certainly solve your problem, ?
What I recommend is print pdf files as images, you will find this option in the print dialogue box, unfortunately, i don't have access to a Mac OS 9 machine to take snapshots to show you, but, if you snoop around the print dialogue options, I'm sure you'll find ( Print as Image ) and that feature really reduces the weight of the image you are sending to the printer.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
