Please let us know the model number of your unit. This can typically be found on the back of the display, or the front page of the instruction booklet. This will allow us to better assist you.
Testimonial: "Model 02010"
Please visit our Knowledge Base for helpful tips and troubleshooint steps.http://www.acurite.com/kbase/02010_02014... If you need further assistance, please contact Customer Support at 1-877-221-1252 or [email protected]. Thanks!
This all depends where u have your sensor if out doors keep out of sun light and a northern exposure is recommended If your temperature is off on your indoor readings consider where both sensors are
Testimonial: "I have my sensor facing north out fo the sunlight.Out door & in door temperatures are desplayed . the outdoor temp is 4% higher them the actual temp."
I had a simular issue where are you getting the four degree differnence temperature from? If it is from an air port weather channel or radio that could be the difference . The sensor will only give the actuall temperature for where it is placed . Also keep in mind this unit probally has an accuracy of minus or plus 2 degrees .
Please note that these sensors have an accuracy of a minus or positive 3 . I have a very expensive unit with an accuracy of 1 degree F
