Question about ZEEPAD 7 inch Android 2.2 Tablet
I got locked out forgot my pin how do I factory reset the tablet
Raj Patel
    Genius:
  • 1,041 Answers
Switch the tablet off. Then press the volume up button and keep it pressed while switching on the tablet. The tablet should stat in a special configuration mode. There will be a menu with the option to do a factory rest.
Posted on Mar 16, 2015
Trying to find my lost s pin to my Samsung tab2
How do you reset your tablet if you forgot your password?
Feedback
lock screens - Disable the screenlock on Samsung Galaxy Tab with ...
https://android.stackexchange.com/.../disable-the-screenlock-on-samsung-galaxy-tab-... Aug 6, 2014 - To Hard Reset please follow the below steps. With the device off, press and hold Volume Up, Power and Home button. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Can't do factory reset on Galaxy Tab 2
25 Dec 2015
lock screens - How to disable pin security from Samsing Tab 2 ...
4 Mar 2013
How to force Samsung Galaxy Tab to shutdown?
5 Mar 2012
More results from android.stackexchange.com
How to unlock Samsung Galaxy Tab 2 password without losing data ...
visihow.com/How_to_unlock_Samsung_tab2_password_without_losing_data Jump to I allowed my friend to use my tablet. she has put a password on MY ... - There is no way to bypass that pin lock without hard resetting a RCA tablet. You can certainly try accessing with your Google Account but usually on the RCA tablets they have to be hard reset. RCA has created a Video ... ‎How to unlock Samsung ... · ‎I forgot my Galaxy Tab2 ... · ‎Sir, I lost my Android ...
How to Unlock Samsung Galaxy Tab Without Losing Data
www.samsung-android-transfer.com/recover.../how-to-unlock-samsung-galaxy-tab.ht... Dec 21, 2017 - One click to unlock screen Samsung Galaxy Tab without losing data, remove lock screen PIN, Pattern, Passcode and Fingerprint on Samsung Galaxy Tab ... screen pattern of my Galaxy Tab 3, there are still too many important file on my tablet, how can I do to bypass the lock screen without losing any data?
If You Forgot the Password on Your Galaxy Tab S2 - Samsung
https://www.samsung.com/us/support/answer/ANS00050633/ If You Forgot the Password on Your Galaxy Tab S2. If you have a Samsung account set up on your device, you can unlock your device remotely on the Find My Mobile web page. Screens and settings available may vary by wireless service provider and software version. If you don't have a Samsung account, factory reset is ...
Samsung Galaxy Tab 2 7.0 Hard Reset/Remove Password - YouTube
? 3:28
https://www.youtube.com/watch?v=LAHYEYtCMuM Mar 22, 2014 - Uploaded by Oxford Street Tech
Transcript. The interactive transcript could not be loaded. Loading... Loading... Rating is available when the ...
Mar 05, 2018 | Samsung Tablets & eReaders
Forgot pin code
Angie, You can may have to do factory reset. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Forgot Lock Screen Password or PIN
http://forums.androidcentral.com/samsung-galaxy-note-2/250290-omg-forgot-pin-can-t-get-past-lock-screen.html
Tablets and eReaders Faq
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
Apr 07, 2016 | Tablets & eReaders
Why did I lock myself out of my tablet?
How do I unlock my Tablet when it's locked with a pin code ...
visihow.com/How_i_unlock_my_tablet_when_its_lock_with_pin_code
I locked my tab with a pin lock and I forgot the code. ... Locked out of my Samsung Galaxy S2 i91000? .... can use, the following steps (as well as the video above) in order to help yourself to get back into your device by using a reset combination: .... Cannot get my screen on my tablet to unlock, don't remember pin number?
My Tablet has been locked and I also forgot its Google ID ...
visihow.com/I_have_locked_my_tablet_and_now_I_do_not_know_its_...
The easiest way out right now would be to reset your Tablet. Press the ... Yes ' No ' I need help. See more questions like this: I forgot my pin password on my o+ mobile ...My Android phone has been locked and it asks for Google accounts, but I don't remember which one I used. .... I've tried to break into it myself. How can I ...
Hard reset your Android phone or tablet when you forget the ...
Jan 01, 2016 | Irulu 7" 4gb Mid Google Android 2.3...
How can I reset my tablet?
    1. Here's how to execute a factory reset:
      1. Turn your tablet off and remove the SD card, if there is one.
      2. Press and hold the combinations below until you feel the device vibrate: Power button + Volume up and down (if there is a physical Home button) Power button + Volume up + Home button (If there is a physical Home button)
      Forgot your tablet's password? - TechAdvisory.org
      www.techadvisory.org/2013/03/forgot-your-tablets-password/
    Feedback
  1. Forgotten Pattern, PIN or Password on an Android device
    acer.custhelp.com/.../forgotten-pattern,-pin-or-password-on-an-android-...
    What can I do if I set a Pattern, PIN, or Password on my Lock screen but forgot it? ...If you do not have Android Device Manager installed, the tablet must be reset ...
Nov 29, 2015 | Tablets & eReaders
How do i factory reset my kuno tablet that i forgot all passwords to
Look for a small pin hole in case, usually says reset next to it. Use a paper clip in the hole to press reset button. Power on while momentarily holding down reset button with clip. Then power on again, should be back to factory settings. If there's no pin hole the you hold down on off the f keys while powering up. Try googling tablet name & model factory reset.
Jun 09, 2015 | Tablets & eReaders
Change pin number
hard reset by recovey options
Nov 14, 2014 | Tablets & eReaders
How to unlock rca tablet
1. Turn your tablet off.
2. Hold volume up and power button at the same time.
3. Wait until the android dog screen pop up and then the android upside down with a triangle in it will come up the you hit reboot with your volume up or down button and press power for ok.
Mar 01, 2014 | Tablets & eReaders
Forgot my passcode symbol on my tablet an need to reset it please
This works with devices having physical home button
1.
Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory. With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
Note: I Use My Tablet SUNBERRY, and reset my Tablet
Turn Off your Tablet and then
Press Power + Volume Down (Press up Factory menu Show)
If you use Android 2.2 (Froyo)
Press Wipe data / Factory Reset -> Yes, Delete ALL user data -> if Finish press Reboot Now
If you want more other andoroid OS and other tablet visit my Blog
you can see how to Reset android with video
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Feb 14, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
ZEEPAD 7 inch Android 2.2 Tablet Logo
250 people viewed this question
Top ZEEPAD Tablets & eReaders Experts
Harrie
Paul G
Paul G
Ngoro
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
