I have had a new door seal put on and cleaned the pump and washed out the pipe but my washing machine wont spin when it goes on spin cycle it shows f5
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
Posted on Sep 13, 2009
SOURCE: frigidaire washing machine no spin cycle
I had the same problem with my Frigidaire Affinity front load washer. It would go through the wash cycle but would not do the final spin cycle that takes the access water out of the clothes. It would actually cut off when it got to be 6 minutes left. I checked the hoses, belt, motor and pump but all were functioning properly. I even cleaned out the filter thats located in front of the water pump. It was full of coins and other debris but it still didnt fix the problem. I called the repairman and he concluded that the control board was bad and would have to be relaced. The board is $200 and labor $140. It will cost you $340 dollars to correct this problem unless you know how to replace the control board yourself. Only had the washer for 3 years. I wouldnt expect something like that to occur within that short period of time.
Posted on Sep 22, 2009
SOURCE: Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
Posted on Jan 19, 2010
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Mar 05, 2015 | Hoover Washing Machines
Dec 03, 2013 | Washing Machines
Nov 04, 2012 | Beko WME7247W Washing Machine
Mar 21, 2017 | Washing Machines
Nov 06, 2010 | Westinghouse Washing Machines
Jul 12, 2010 | Hotpoint Washing Machines
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Dec 20, 2009 | Washing Machines
Nov 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Aug 20, 2007 | Frigidaire GLTF2940ES Front Load Washer
Jan 01, 2021 | Hotpoint Washing Machines
101 people viewed this question
