GE MODEL- TFX20JR OR TFT20JR serial number LS242981
Check for frozen, iced over evaporator coil caused by defective defrost timer and/or heating element. Ice maker will not work unless freezer temp is around 10 degrees or less.
Testimonial: "Thank you for giving me something to check. I hope I can pin point the problem now with this suggestion."
SOURCE: GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
SOURCE: GE SIDE X SIDE Dispenser problem
Sound like maybe a dispenser board short... you could try taking of the top hidge cap on the freezer side unplug the power to the board there for 30 minustes or so plug back in and see if it can reset to default and try that before u have to change board
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
refrigerator side is warm and freezer side is cold in parts and will freezes at the bottom of cabinet. How do i get a repair manual with trouble shooting?
Does my refrigerator have Freon? Can it be low and stop the ice maker from making ice?
