Question about Ovens
The door can barely be opened on a Wolf oven. The hinges are
The door can barely be opened. The hinges are stiff and the door once opened falls. The problem has been getting worse. The local repair company wants $725.00 to fix it.
  • Capt Rick May 11, 2010
    What kind of oven ?
Anonymous
I called Wolf customer care and they are sending me a new door. No Charge. NOW THATS CUSTOMER CARE.
Posted on Jul 10, 2009
How do I remove oven door
open the oven door all the way and look down at the hinges. there is a little locking clip that you swing into position that locks the hinge from closing. it might be stiff and need some cleaning depending on how old and dirty your oven is. Also you might have to push down on the oven door to make the hinge open fully to get the locking tabs into place. making shore that the locking clips stay in place and hold open the hinge as you lift the oven door slowly towards its closing position and you will see the whole hinge lift up from inside the oven cabinet and the door will just lift out. be careful not to catch your fingers. make sure the looking tabs stay in place during removal as the hinge is very hard to get back into this position again. re fitting is the reversal making sure that you have pushed the base of the door all the way back into the cabinet and push down on the as to open it to release the tabs.
Sep 23, 2016 | Ovens
The oven door will not close .
i just had a similar problem .the door would fall and i had to lift the top of my door hinge to close it .I found that the pin on the door hinge spring had fall.en out . I installed it back and now it works the way it should.the spring should feel tight with no movement.
Mar 25, 2014 | Dacor MCS130 Millennia Electric Single...
How do I know if the hinge is broken on the stove door?
the door will fall off when opened if both hinges are broken, if only one hinge is broken the door will drop down on one side.
Apr 20, 2012 | Brown Stove Works Ovens
Oven door falls open and will not close tight on my Jenn-air Single oven Model #SVE47100w
The hinges and receivers would need to be replaced on this. The hinges are part number 71003351 you need 2, they go inside the door, so the door would need disassembled.
The receivers (hinge receptacles)are part number 71002206 you need 2 also, these go on the side of the oven. You will need to pull the oven out a few inches to gain access to these
Jul 24, 2010 | Jenn-Air Electric Single Oven
How to unlock the hinge on an Ariston Oven Door with door off
To Unlock the hinge on an Ariston Oven Door
Lay the oven door flat on the worktop with the inner door upwards and the locked hinge facing you.
With a pair of pliers and a good grip on the hinge, force the locked hinge towards you (by pulling it open towards you) and keep it in position by flipping the U piece over.
Fitting the Oven Door
Fit the door to the oven with the metal receivers in the slots on the oven.
Once the receivers are in the slot, fully open the door (in a downward position).
Flip the U shaped pieces over to lock the hinges.
May 17, 2010 | Ovens
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Jan 08, 2010 | Whirlpool GMC275PD Electric Double Oven
The door no longer closes correctly leaving a gap at the top. When open it is no longer horizontal but falls to a downward slant
It sounds to me that the oven door hinges need to be replaced, especially if it is a drop down door
They need replacing as a pair.
There is no povision made for adjustment on hinges.
Hope this helps you.
Dec 08, 2009 | Miele H340-2 BP Pyrolytic Electric Single...
Whirlpool GMC275PD build in electric double oven
I have a different model Whirlpool oven but if the door opens downwards then there are usually two smalll catches on top of the main hinges. Lift these up (they can be quite stiff) away from the oven, partially close the door and it should lift upwards to free the hinges.
Hope this helps
Sep 14, 2009 | Ovens
My oven door no longer closes properly it falls back open
Hi
you dont say what make or model it is, but from what you do say sounds like the door hinges have failed just replace and should be back to normall.
regards dan
Mar 19, 2009 | Ovens
I have a Whirlpool Oven #SF395LEE* (RB26126336) accubake Systems. Today the oven door came off and I need to know how to put it back on. I do not see this over on your list. Can you help? Thank...
ok wht you have to do is grab the hinge with pliers or your hand and fold the hinge to the open position,carefull this hinge has some pressure to it and you dont want to pinch your skin ,once the hinge is open,you want to take a screw or strong nail and stick it thru the hole that is between the top of the hinge and bottom in the center put the nail thru the hole and let the hinge close slow i,it will hold the hinge 3/4 open,now hook the door on it will be 3/4 open once you feel it latch on the door open the door all the way pull the nails out and close the door ,it takes a little practice but youll get it remember to use the nail to hold the hinge open,youll see the hole on the hinge
Jul 13, 2008 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
422 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
john h
Are you an Oven Expert? Answer questions, earn points and help others
