SOURCE: Coffee maker not working
Dear Sir/madam,
Please contact our Customer Service department at 1-866-901-BREW (2739) to make service arrangements.
and Try also
PREPARE
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (do not use a paper cup.)
Step 2: Empty the water in the Water Reservoir b. FILL AND CLEAN
Step 1: Pour the vinegar into the Water Reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the Drip Tray and run a brew cycle. DO NOT USE A K-CUP…just press the Large Cup Button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the Water Reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill reservoir with fresh water and let the Brewer stand for 4 hours while still on.
Step 5: Rinse the Water Reservoir thoroughly and fill with fresh water. c. RINSE Step 1: Ensure the Water Reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the Drip Tray and run a regular brew cycle. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the Water Reservoir is empty. Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Regular cleaning (de-scaling) will prolong the life of the appliance.
Scale is harmless, but left unattended, it can hinder optimal Brewer
performance. De-scaling your Brewer regularly helps maintain the
heating element, water reservoir and other parts of the Brewer that
come in contact with water. Better water quality and water heating
means a better cup of coffee. We recommend de-scaling your Brewer at
least every 6 months (every three months if you are using hard water).
The descaling process involves using 48 ounces of undiluted white
vinegar.
Regular cleaning of the Brewer’s external components is recommended for
proper operation. We recommend cleaning with a soapy, damp non-abrasive
cloth. The K-Cup holder and funnel, drip plate, drip tray and removable
water reservoir (on the Elite B40, Special Edition B60, and Platinum
B70) are dishwasher safe. NOTE: the removable lid of the water reservoir is NOT dishwasher safe. The brewer should be descaled every 3-6 months.
Check out the Link for more information:
http://www.keurig.com/
faq.asp?mscsid=J5HAXXHH0GNG9LXP576CPCG47B500439#brewer9
Don't forget to rate the solution
Thanks
SOURCE: Espresso stopped working
Possibly you might need the Brew Head Screen and/or filter basket cleaned of built up coffee oils. Depending on how much you use it, is best to clean it every week or couple of weeks.
Remove brew head screen and filter basket, also if you have a screw in the filter basket and soak with in a cleaner for removing oils (not descaler) at: www.urnex.com or Dezcal etc.
Or, if you have not used it in awhile you might need to prime the pump manually:
Fill water tank.
Turn power on.
Open the steam knob all the way.
Press the coffee button.
Put a cup under the steam pump wand.
Wait until you see a steady flow of water and no air.
When you see the flow of water, close the steam knob.
Turn off the coffee button.
Now the machine should be ready to brew an espresso.
For further details email: [email protected] or the service center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
[email protected]
www.electra-craft.com
SOURCE: keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
SOURCE: Senseo coffee maker not working
One of two things, first of all, it wont open until it cools down/depressurizes. First problem is that the ground coffee is two fine, and the second possible problem is that the coffee is packed too tightly. That is assuming that you dont use the pads but coffee pad adapters.
SOURCE: I'm having a flow problem with my keurig brewer.
you will need to give it a vinegar flush..white vinegar..I put about 1/2 cup with a full tank of water..keep running the water until empty..then run thru a full load of clean water..then taste some of the hot water..to see if the taste is gone....
you do not need to use k-cups for this
