Archos Internet Media Tablet MP3 Player Logo
Posted on Jul 09, 2009
First time charging up of archos 5.just the green light on it didnt say usb enable or charge only.archos logo keeps flashing on and off every few minutes.is this right. it has now been charging for about 4 hours.
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Aug 24, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
Helped
11059
Points
20
Your archos probably has a glitch in it. You might have to do a system recovery of it. First download the latest firmware program from Archos website. Here is a quick possible fix when the screen comes up reset the archos by inserting a paperclip in the reset hole located at the bottom of the unit right of the connectors it might work it might not. if that doesn't fix the problem do a hard reset when the logo screen comes up hold down the volume+ button until the white recovery page comes up. First try repairing the unit if that doesn't work try format and follow the instructions. the touch screen doesn't function during the recovery page so use the volume+&- buttons & power button. When you get done your archos should be set to factory presets so you have to set it up. Good Luck
1helpful
Archos 5 not working, will not switch on.
Hi I would think the best place to start is with ARCHOS,
give them the lowdown and see what they come up with.
You could use the Archos forum and look through the help files
2helpful
2answers
First time charging up of archos 5,it has now been charging for about 14-15 hours. but the green light did'nt blink yet. it says after fully charge, the green light blinking. what can be the promlem about...
@wilkerwkocer
On an Archos, battery is fully charge when the CHG LED light is flashing, while that light is ON all the time, the unit is still charging.
Now, in order to charge your Archos you must leave it on Suspended mode, by holding the Power button for about 4-5 seconds until it says "Suspending", DO NOT leave it on completely "Shutdown" mode, or your battery will never charge, and you are also risking the life of your battery by doing so.
So in other words:
1) On a PC via USB it should take around 8 hours to charge, while connected to an Archos mini dock, battery dock, or DVR Station, it should take around 3 hours to fully charge.
2) Leave your unit completely "Shutdown" (hold the Power button and wait 10 secs. or so until it says "Shutting down" and let it go off.
3) Connect it to your power source, either USB on computer, or external charging device as mentioned above, it will come back on, the two LED lights CHG and Power will come on, leave it like that, and after a few minutes the unit will go into Standby/Suspended mode by itself, and there is when you are charging your battery the right way.
3) Wait 8 hours if connected to your PC, or 3 hours if connected to an external power supply (as described above). If still after being in suspended mode (not completely off) your CHG light isn't blinking after the 8 hours on PC, 3 hours on external power supply, then suspect your battery is defective.
In that case, if the unit is still under warranty contact Archos, if it is out of warranty. If it isn't under warranty, you can buy a replacement battery on eBay and either replace it yourself, or find someone with the technical skill to do it for you.
I hope this helped you.
2helpful
2answers
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
2answers
Charging for 30 hours so far...
mine seemed to take ages on the first charge but after like 3 days or so the light started to blink.
My archos 7 wont charge the red light comes on but wont charge tried resetting batery no use put a new battery in green light came on looked like charging but didnt in the end
If the archos was purchased new from Archos stores they have warranty on them call tech support to find out. Have your serial number and product model number handy.
Logo keeps flashing and won't take a charge.
there might be a problem with the phone or USB cable that ur using for charging, you can have it checked by using another USB port on your PC, try using another cable as well if it did nto work the phone needs service.
Archos 604 will not restart
i had this problem recently when charging on the DVR docking station, i switched it off, took the battery off, left it for a shirt time then pressed the reset, it took a few attempts but eventually it restarted
Archos 704 wifi not starting up
If you enter recovery mode then connect to a computer, you can then use windows drive checker to verify the drive. If all is OK, copy firmware to the root then disconnect and reboot
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
