Question about Rolex Watches
How much us a Rolex oyster perpetual day-date worth ? And, is it real ? The back says Rolex genuine swiss made
Has blue colored face and the rest yellow gold colored, and do you want to buy it ?
Posted by robertduvall on
Mister Danger
  • Rolex Master
  • 5,631 Answers
If it's Gold might worth about 6000 - 6500 but the only way to tell if it is genuine is to take it to n expert. There are many fake rolex around that woth nothing
Posted on Apr 26, 2015
Andres
    New Friend:
    Problem Solver:
  • 5 Answers
If 36mm size 6,500 us
5 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I can not open rolex bracelet
Sometimes Rolex bracelet clasps are very tight and this only shows the quality of the watch.
Don't be afraid to pull the clasp hard enough to open it- nothing will brake as Rolex is designed for quite hard use.
If you can't do it by hand, try to use flat butter knife end as a lever.
Posted on Dec 17, 2008
Anonymous
  • 26 Answers
SOURCE: Rolex oyster perpetual datejust time/date setting instructions
Unscrew the crown pull out the crown to the first position, One click and rotate the crown clockwise. This is for Quick Set models
For non quickset
Posted on Jan 03, 2009
Anonymous
  • 26 Answers
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
Posted on Jan 06, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: how to adjust day date on older rolex perpetual day date watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Posted on Mar 07, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I need an owner's manual for a Rolex Oyster
Posted on Mar 31, 2009
What is this womens 14 k gold watch worth?
Without more information, "only what someone will pay." The name on the face, or back, should be entered into a search engine and lead you to sites which sell watches, and show you pictures for you to match against.
May 14, 2016 | Watches
Does the Movado ladies watch serial number 74259821 836092 have a solid 14K wrist band?
The 74259821 is definitely a 14k solid gold watch. I have one, too, and need an extra link for it if anyone out there has one. 267465b2-5058-4a86-99d3-8e2eb936415b.jpg 83ef6643-49bf-4f76-97f1-639d71b4c025.jpg
Sep 15, 2014 | Movado Museum Watches
I have a Pierre Cardin Primero watch 8007YB that says 18k on it's face. Does that mean it is real gold or could that still mean gold plated?
Unless it is fake, this is a real gold, but only the dial (you call it face, which is wrong). To check the authenticity of your watch you have to shoe it to watchmaker.
Apr 02, 2011 | Pierre Cardin J54995
I looked at a daytona two-tone the other day. The edges of the gold parts of the band had turned like a black color. Is this normal?
Most likely a fake watch. Rolex makes white gold, yellow gold, platinum and stainless steel watches. Almost always solid metal parts and not plated. It sounds as the plating on your watch is worn through and the underlying metal is oxidizing.
Mar 11, 2011 | Rolex SS/18kt Daytona
I have an older skyhawk watch, but the paint came off the bezel so you can't read the numbers. How much would it cost to get them repainted or replace the bezel?
I had the same issue. I found a way that makes the watch look new again. If you buy a sharpie marker and color the whole face It will color in the numbers and around them. t After you have done that, rub a moistened rag over the face of the watch. This will remove all the excess black marker, and it should look new for a few months.
Dec 19, 2010 | Citizen Blue Angels Skyhawk Watch
I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
Apr 27, 2008 | Seiko 0512039FA Wrist Watch
Watches Logo
401 people viewed this question
Top Rolex Watches Experts
Bruce Robin
Janelle Schoonover
Janelle Schoonover
Are you a Rolex Watch Expert? Answer questions, earn points and help others
