Question about Avaya Corded Phone avaparp18d
I can't set up the intercom system on my Avaya Partner ACS R7
I had to replace the process module on my Avaya Partner ACS R7 phone system. It was fried due to a power outage.
I assigned buttons on the phone to each individual extension in the office. I used to be able to hit an extension button and talk over the loud speaker on the extension. I can't get the intercom system to work so I can page a phone in another room. If I hit an extension button, the display says I'm transferring a call.
Any ideas?
Posted by barb988 on
Anonymous
To program a page button for other extensions.
At the phone, press Feature 00
press the LIGHTED button you want to program.
press the LEFT intercom button, followed by * (star) and the 2 digit extension number.
Repeat for more buttons.
Feature 00 when done.
Now you can just press the button, and it dials intercom *10 (example)
it will activate the speakerphone and you can talk.
Posted on Jul 09, 2009
Reset acs 308ec to factory settings
Im assuming you mean an ACS 308 processor not the 308ec expansion module. From a display phone at either extension 10 or 11 press feature 00 - left intercom button twice - #98925327
tip
Change time/date on Partner ACS processors
<i><b>Partner ACS, any release</b></i><br><b>Changing the time on a Partner system must be done from extension # <b>10 </b>or <b>11</b>.</b><br><b>1. At station(Ext.10 or 11) press feature, 0, 0<br> 2. Press the left intercom 2 times<br> 3. Enter # 103<br> 4. Enter the correct time in 24 hr. format, for example:<br> * to set the time for 09:00 A.M., enter 0900<br> * to set the time for 04:45 P.M., enter 1645<br> 5. Press feature, 0, 0</b><br><a href="http://www.Telemanuals.com"></a>
Page port testing
I am not sure what #617 is but the loudspeaker paging access code on the Partner ACS is intercom 70. If no audio is heard from the paging port on a test set when this is dialed then the paging port is defective. There is no programming necessary to enable or disable the loudspeaker paging access code.
1helpful
How do you change the time on the Avaya phone 700340193
Changing the time on a Partner system must be done from extension # 10 or 11. 1. At station(Ext.10 or 11) press feature, 0, 0
3. Enter # 103
http://dstech1.com/changing-time-on-a-partner/
5helpful
How do I reset the time?
3. Enter # 103
1helpful
I need to set the ringers to only ring at the two receptionist desks and not everyone else's offices. Please help! We have Avaya Partner 18D phones.
Partner ACS systems come with Centralized programming instructions. Most of them starting with Feature 00 Left Intercom twice and Right Intercom. When you dial an extension, the lights will be solid or blink according to how it's programmed and you press each button to turn on or off or delay ringing.
Your system administrator should have a book.
Carl
12helpful
How do i change the time on my avaya 18d series 2 partner phone
3. Enter # 103
I bought a used avaya partner phone system online. It came with Partner mail vs module... I cannot access the menu for voice mail to set it up... Avaya directions say pressing (intercom) 777 but all I get...
Did you really think it was going to be that easy?
You have to program the VS in the proper hunt group (7) to make it work. For example, if you put it in the 2nd slot, because it was only a 2-slot carrier, it would become extensions 22 and 23 on a 2-port license and 20-23 on a 4-port. The Partner Mail is installed to the right of any 206 or 400 cards, so that you don't have any holes in the extension numbering plan.
Here's a manual for the VS R4. It should work for your system for the basic installation. http://public.carl.airpost.net/Avaya/Partner%20Mail%20VS%20R4%20Installation%20and%20Programming.pdf
Page 35 is your installation information and page 50 tells you how to program the ACS.
Good luck.
Carl
USED AVAYA ACS V7 PARTNER MAIL vm SYS ANSWERING ALL CALLS, I CAN'T ACCESS VM SYSTEM
Depending on the type of voicemail you have, That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.If you mave a Partner Messaging System2.gif the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming2.gif.
After pushing 103 the phone just beeps and does not go into time
3. Enter # 103
Avaya Corded Phone avaparp18d Logo
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ekse
Muzahura Frank
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
