The engine Electronic Control Module (ECM) monitors the oil pressure on CAT engines. The Electronic Control System (ECS) for the engine sends the information to the GSC+P. Your setting yourself for extreme and quick success if you use a CAT ET(Electronic Technician)
http://www.empire-cat.com/catet/ Good Luck.
Since you want to test only low oil pressure shut down, so just use a trimmer and cat ET to trim down the pressure of oil to shut down setting and see whether the engine can be shut down according to the spec.
This is a critical element to protect the engine. Shop manual is needed. You can try manulslib.com but they may not have it.
So ask the dealer or MFG for one.
