Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I moved into a new house and they had a sears craftsman 1/2hp garage door opener. I had 2 existing openers from my previous home which I want to program to this new opener...how do i do this?
Posted by harris_22 on
Nate Stansfield
  • 11,896 Answers
With the garage door closed, press the large button on the remote. While that is pressed, press the "learn" button (ours is red) on the back of the opener unit. The indicator light on the panel will begin to blink and the opener light will flash once. At that point, release all buttons, and try out your remote!
You should be able to program your garage door remote after reading this!
I will be talking about Liftmaster and Craftsman garage door openers. The Chamberlain Corporation makes Craftsman, Chamberlain, and Sears Craftsman garage door openers. Whether you have a chain drive, a screw drive, or, a belt drive opener, they all program the same. There is a "learn" button on the machine that holds the information from the remote control. The learn button may be located on the side of the opener but, most models have them on the rear of the machine. How you can locate the button easily is to find where all of the wires are running into the machine. The learn button is usually square, but, it can be round. The colors of the buttons can be white, yellow, green, red, or the new frequency is purple.
Look at the photo above and you can see the square (red) button located on the left side of the "Logic board". The logic board is the computer that tells the opener whatto do and when to do it. It is also usually the first thing that lightening will hit in a thunder storm. I basically is a radio frequency receiver that picks up electrically transmitted signals. Lightening is an electrical signal, and a very powerful one. The little wire on the bottom right side of the logic board is the receivers antenna. DO NOT CUT IT OFF! I have have been to houses that the homeowners complained about the remote control only working when they get really close to the door. When you cut the wire you alter the frequency of the remote control, and have to replace the logic board. The logic board can cost anywhere from 85.00 up to 100.00 depending on your area. Oh, the prices i just quoted didn't include labor.
Now, for the programing part you have been waiting for. Hold down the square or round learn button that is on your opener for about 20 seconds. This clears any other remote controls that may have been in the machine. NOTE: If you loose your remote control, or, if you are going thru a divorce, you need the clear the opener so that unwanted people can no longer have access to your house. Another tip..... when you go to have your car serviced make sure you keep your remote control with you!
The reason i say this, is not because i am saying car dealerships or repairmen are crooks, but, there are exceptions to every rule. When you go to get your vehicle repaired you give the people your name, address, and your remote control. I know of one problem where a customer dropped off her Mercedes to be worked on and the mechanic had her address, and took her remote control, and went to her house that night and stole her car. Just stick it into your pocket until you get your car back.
Ok, once cleared, you take each remote control, and go to the back of the opener where the learn button is. Hold the remote control button down, and push and release the learn button. You should hear a click, and the lights on the machine may come on for a split second. When this happens, the remote control is programmed. Continue this process until all remotes are programmed. Note: The opener will only hold five remote controls, or, four remote controls and one keyless entry.
Posted on Jul 09, 2009
I have bought a second remote control craftsman 315 918191 i have remote device install with my crafftsman door opener there is no learn buttom on either device what can i do thank you
Post the model number of your opener. It is on the end of the motor unit nearest the door. It starts with 139. Also post the model number of your new remote. It should also start with 139.
Mar 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
Is there a univeral remote for craftsman garage door openers?
Depends on the age of the opener. The model number is on the end of the opener closest to the door. Using it go to Sears parts and you can find out if the remote is still available.
Dec 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage door opener does not open or close
The drive gear is most likely stripped. It is a white nylon gear just in front of the motor. The parts number is 41A2817 and is available from Sears or any good door opener service company. It comes with instructions.
Jun 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cant get wireless Keypad to Link to new Garage Door Opener
The radio frequency has changed and the old keypad will not work with the new opener.
Mar 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 hp garage door not running at all
DOES IT WORK FROM THE WALL BUTTON??
IF NOT YOU MAY HAVE A BAD CAPACITOR - UNPLUG THE UNIT TAKE OFF THE COVER AND LOOK FOR A ROUND TUBE THAT HAS 4 WIRES CONNECTED ON ONE END . IF IT IS LEAKING OIL OR HAS A BROWN OR BURNED LOOK ON THE CARDBOARD END WITH THE WIRES IT IS MOST LIKELY BAD.
SHOULD BE AVAILABLE FROM ANY MOTOR REPAIR SHOP
HOPE THIS HELPS
May 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
380 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
