Question about MyMusix PD-6030 MP3 Player
Dead MP3 Player?
I purchased this PD-6030 for my daughter for Christmas last year and it has suddenly stopped working. When accessing this player in My Computer it shows 0 bytes used 0 bytes free. When I choose to Format it tells me to insert a disk and try again. I wish there was a reset button somewhere or it would let me reformat because it worked great when we first got it and suddenly without warning............nothing........it became an expensive piece of decoration. Anyone have any solutions or advice?
Posted by ladyroto on
  • Anonymous Jan 23, 2008
    no memery on it cant download any thing on it helpppppp??!?!?!
ThaMp3Doctor
  • 8,597 Answers
MyMusix's PD-6030:
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
Posted on May 24, 2008
What do you do when the mp3 player says flash error?
Hello.
Welcome To Fixya's Community
Glad To help you.
In order to Fix Your Problem with the "Flash Error" Message on your PD-6030 Mp3 Player try these three Solutions.
Solution 1:
hold in the volume + button, and reconnect the player to the computerwhile holding the volume + button in. Keep holding the volume + buttonfor an additional 5-50 seconds. Windows should eventually go intorecovery mode and revive the player- it will pop up a window that saysFound New Hardware Wizard.
Solution 2:
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. -Connect player to computer, click my computer, right click on icon ofmp3 player and select format.
Solution 3:
You will need to Update the Firmaware of your Mp3 Player in Order to Do Download The utility from the link below and follow instructions.
Downloads :
Player Update v3.
Additional Help:
Download : PD-6030 Manual Guide.
Please if Ask me If you need any Further Info.
Thank You For using Fixya.
Good Luck.
Nov 05, 2009 | MyMusix PD-6030 MP3 Player
MyMusix PD 6030 persistently displays flash error! please backup the data and format the player. This happened after I tried to replace an existing playlist with a new one.
I would recommend you do back up your files to the computer and then format the player.
Q: How do I format my PD-6030?
A: There are various way to format the PD-6030.
With Windows XP, go to Start, All Programs and select 'My Computer'. Then see if there is a device called an 'Audio Player' listed there. If so , open the Audio Player and right click the item named 'Internal Storage' and select 'Format'. Once the format is complete, unplug the player and turn it on. Once it turns on and says 'No Files' plug it back in to your PC and add the music back to the player.
With older version of Windows, the player will show up under 'My Computer' as a 'Removable Disk'. Right click that and select "format'.
Oct 16, 2009 | MyMusix Audio Players & Recorders
Flash error backup data and format
just connect it to the computer then save all ur folders to ur desktop thats the easy way to back up data
May 15, 2009 | MyMusix PD-6030 MP3 Player
Battery won't hold charge
Hello Sir,
I know all model of the Astar brand models. Please call me at 323-767-6030 I will go through with you and the testing of your battery.
Jul 31, 2008 | Astar PD-3010 Portable DVD Player
My mp3 player wont turn on
This might be a tricky one to solve - may take more than one method.
Start by resetting the player. Then replugging it into the computer.
If it still fails:
Uninstall the PD-6030 via device manager. The PD-6030 needs to plugged in to do this. Go to Start, Control Panel and select 'Performance an Maintenance'. Then Select 'System'. Then select the 'Hardware Tab' and select 'Device Manager'. Then find a device called 'Portable Devices' or 'Windows Portable Device'. Then select the + sign next to the device and right click the 'Audio Player'. Select 'Uninstall'. Click 'OK' when it asks you if it is OK to uninstall. Then select 'Action' at the top of the Window and select 'Scan for hardware changes'. Then once it re-installs the driver, see it operates
correctly. Also, performing a firmware recovery procedure can work to make your computer recognize the PD-6030. Please follow the set of instructions titled, "Q: How to recover my player's firmware?".
The firmware upgrade can be found at www.mymusix.com
-Tha Mp3 Doctor
Jun 13, 2008 | MyMusix PD-6030 MP3 Player
Player will not work
If that fails,
If that fails,
-Tha Mp3 Doctor
May 23, 2008 | MyMusix PD-6030 MP3 Player
Ilo mp3 player
Reset it , restart your computer, and try again
Apr 23, 2008 | iLO (2 GB) MP3 Player
Mymusix pd-6030 player
MyMusix's PD-6030:
If that fails,
If that fails,
-Tha Mp3 Doctor
Nov 29, 2007 | MyMusix PD-6030 MP3 Player
Flash error
same here just a diff mp3 ...
Nov 25, 2007 | MyMusix PD-6030 MP3 Player
PD-6030 MP3 player flash error message
MyMusix's PD-6030:
If that fails,
If that fails,
-Tha Mp3 Doctor
Nov 08, 2007 | MyMusix PD-6030 MP3 Player
MyMusix PD-6030 MP3 Player Logo
67 people viewed this question
Top MyMusix Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
