Televison & Video Logo
M
Mick steele Posted on Mar 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Quick fix? Hi,the TV was switched on the it made a small pop/crack noise then nothing not even standby light, I have cheaked the mains fuse, is it RIP? Ta for any help. Mick.....
The Wyzzyrd
Level 2:
  • Expert 108 Answers
  • Posted on Mar 14, 2015
The Wyzzyrd
Expert
Level 2:
Answers
108
Questions
0
Helped
29962
Points
255
Hi Mick. Well, it's rare that the main fuse fixes TVs any more. Look for burn marks on the integrated circuits (ICs), or capacitors (sorta shaped like a AA battery standing on end) that are domed on top. If you find either of those, that board needs changed, but if you do see burnt ICs, there might be other boards affected. Sometimes it's better to have a professional look at it.
Testimonial: "Thanks for that, I'll take the back off then!"
  • The Wyzzyrd Mar 14, 2015
    Off the top of my head I would guess the power board is bad because you don't have the standby light, but the main can cause that as well.
TV was on then made a small pop/crack noise then nothing not even standby indicator
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Alba portable tv/dvd combi
Main board fault. Contact any service technician.
Hi, I switched off my Samsung TV last night as usual, and when I tried to switch it on this evening it wouldn't switch on.I tried unplugging it and turning it on, but the red power light on the b
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo. 11_6_2012_3_22_05_pm.jpg
Is there a quick fix for an Element tv series (3710). It alternates with a red and blue light in the front right bottom
I see so many here with no sound/nopicture issues:
ISSUES:
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_30_2012_3_44_36_pm.jpg5_30_2012_3_44_52_pm.jpg
Loud cracking noise followed by no power on 40'' polaroid tv
ISSUES:
Answers to issues:
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
2answers
Hi,my LG 26LB75 LCD TV displays nothing at all,no standby
hey man,
i have th same problem. have you find any solution?
Today i will verify, if the problem isn't it in noise filter IF - N06AEW.
I will post a result. Please let me know about your solution.
thanx
mailto: [email protected]
Not loading up to main screen
ok go to youtube and type" PS3 REPAIR/FIX" basicly what you do is put the ps3 on standby (the red light on) and then turn the main power off (the back switch) then hold the I/O button in the front (the on switch you use to put on standby) just hold it until it will go to standby then hold the I/O button again (the standby button) and then keep holding it until you hear one beep, then wait for two quick beeps. Then there should be a menu and select "Restore Defualt Settings". If it dosent work CONTACT SONY!
5helpful
2answers
No power to my Hitachi 42Pd6600 plasma tv
the master switch at the bottome of the TV per Brianbuy solved my problem...Thank you!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
