2008 Lincoln Navigator Logo
Kimbo West Posted on Mar 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Define the code...how to repair, estimated repair cos t
OBD code U1900...meaning how to repair....estimate repair cost
Mark Andrews
Level 2:
New Friend:
  • Expert 34 Answers
  • Posted on Mar 14, 2015
Mark Andrews
Expert
Level 2:
New Friend:
Answers
34
Questions
Helped
6041
Points
103
U1000 SCP (J1850) Invalid or Missing Data for Primary Id U1001 SCP (J1850) Invalid or Missing Data for Primary Id U1002 SCP (J1850) Invalid or Missing Data for Primary Id U1003 SCP (J1850) Invalid or Missing Data for Primary Id U1004 SCP (J1850) Invalid or Missing Data for EEC Programming U1005 SCP (J1850) Invalid or Missing Data for EEC Programming U1006 SCP (J1850) Invalid or Missing Data for Primary Id U1007 SCP (J1850) Invalid or Missing Data for Primary Id U1008 SCP (J1850) Invalid or Missing Data for Engine Torque U1009 SCP (J1850) Invalid or Missing Data for Engine Torque U1010 SCP (J1850) Invalid or Missing Data for Engine Air Intake U1011 SCP (J1850) Invalid or Missing Data for Engine Air Intake U1012 SCP (J1850) Invalid or Missing Data for Primary Id U1013 SCP (J1850) Invalid or Missing Data for Primary Id U1014 SCP (J1850) Invalid or Missing Data for Primary Id U1015 SCP (J1850) Invalid or Missing Data for Primary Id U1016 SCP (J1850) Invalid or Missing Data for Primary Id U1017 SCP (J1850) Invalid or Missing Data for Primary Id U1018 SCP (J1850) Invalid or Missing Data for Throttle U1019 SCP (J1850) Invalid or Missing Data for Throttle U1020 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch U1021 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch U1022 SCP (J1850) Invalid or Missing Data for Primary Id U1023 SCP (J1850) Invalid or Missing Data for Primary Id U1024 SCP (J1850) Invalid or Missing Data for Primary Id U1025 SCP (J1850) Invalid or Missing Data for Primary Id U1026 SCP (J1850) Invalid or Missing Data for Engine RPM U1027 SCP (J1850) Invalid or Missing Data for Engine RPM U1028 SCP (J1850) Invalid or Missing Data for Primary Id U1029 SCP (J1850) Invalid or Missing Data for Primary Id U1030 SCP (J1850) Invalid or Missing Data for Experimental #1 U1031 SCP (J1850) Invalid or Missing Data for Experimental #1 U1032 SCP (J1850) Invalid or Missing Data for Primary Id U1033 SCP (J1850) Invalid or Missing Data for Primary Id U1034 SCP (J1850) Invalid or Missing Data for Primary Id U1035 SCP (J1850) Invalid or Missing Data for Primary Id U1036 SCP (J1850) Invalid or Missing Data for Wheels U1037 SCP (J1850) Invalid or Missing Data for Wheels U1038 SCP (J1850) Invalid or Missing Data for Primary Id U1039 SCP (J1850) Invalid or Missing Data for Primary Id / Vehicle Speed U1040 SCP (J1850) Invalid or Missing Data for Vehicle Speed U1041 SCP (J1850) Invalid or Missing Data for Vehicle Speed U1042 SCP (J1850) Invalid or Missing Data for Traction Control U1043 SCP (J1850) Invalid or Missing Data for Traction Control U1044 SCP (J1850) Invalid or Missing Data for Traction Motor U1045 SCP (J1850) Invalid or Missing Data for Traction Motor U1046 SCP (J1850) Invalid or Missing Data for Primary Id U1047 SCP (J1850) Invalid or Missing Data for Primary Id U1048 SCP (J1850) Invalid or Missing Data for Primary Id U1049 SCP (J1850) Invalid or Missing Data for Primary Id U1050 SCP (J1850) Invalid or Missing Data for Brakes
How do you replace or fix P0302 or a burnt valve on a 2001 4.0 four wheel drive ford explorer sport trac?
p0302 is a misfire at number 2 cylinder which can be caused by a burnt cylinder up to you to compare cost of repair verses dumping vehicle get estimates on a replacement head --valve ob --engine replacement etc https://www.engine-codes.com/p0302_ford.html https://www.obd-codes.com/p0302
How much to change oil pump on1994 g20 Chevy van with 4.3 engine
Hi Again,this estimate is based on my zip code,you can use your's and get a estimate,all shops have different labor and part cost as you know. Auto Repair Estimates Get Honest Car Repair Costs
1helpful
How and how long to replace heater core on 2004 GMC sierra
Auto Repair Estimates Know How Much Car Repair Costs AutoMD
use that link, enter your year make model engine size and zip code for an estimate
1helpful
2answers
What's the cost to replace an 08 Cadillac thermostat? And how much time would it take if I did it myself?
plug in your year make model engine
the work to be done
and zip code
have fun! this tool gives me the ballpark estimate before i even DIY or bring it to the shop
Po174 po171
most shops will charge you a fee for diagnose this codes and make repairs, take the car to a shop to get an accurate estimate.
I have code p103 what is the estimated repair cost?
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?fromSearchPage=true&pageId=0996b43f802e7729&partName=Mass+Air+Flow++MAF++Sensor&partId=0996b43f802e7729Trouble Code: P0103
MAF Sensor Circuit High Input
Possible Causes:
Check for a restricted inlet screen on the MAF sensor. MAF sensor signal circuit is shorted to system power (B+). MAF sensor is damaged or the PCM has failed.Click on link t view how to repair yourself..
1helpful
2answers
Its ok, to buy 1998 ford taurus wagon, 185 000 km
The 1998 Ford Taurus is a pretty reliable vehicle. Occasional problems on this vehicle are failure of the Camshaft Position Sensor and Actuator; Restricted EGR passages, 3.0L VIN S only; the Differential Pressure Feedback EGR (DPFE) Sensor; the Powertrain Control Module (PCM); and the Secondary Air Injection (SAI) Pump. The cost to repair the Camshaft Position Sensor and Actuator is estimated at $210.00 for parts and $65.00 for labor. The cost to clean out the restricted EGR passages is estimated at $5.00 for parts and $78.00 for labor. The cost to repair the DPFE Sensor is estimated at $76.00 for parts and $32.50 for labor. The cost to repair the PCM is estimated at $320.00 for parts and $65.00 for labor. The cost to repair the SAI Pump is estimated at $200.00 for parts and $52.00 for labor. Other problems on this vehicle are failure of the Transmission Range (TR) Sensor and the Door Ajar Switches. The symptoms associated with failure of the TR Sensor are loss of sound from the radio, loss of power window operation and loss of power steering operation when the car is shifted from park to reverse and/or drive. The cost to repair the TR Sensor is estimated at $40.00 for parts and $39.00 for labor. The cost to repair the Door Ajar Switches is estimated at $22.00 for parts and $45.50 for labor per door and can range from one to four doors. All prices are estimates based on $65 per flat rate hour and do not include diagnostic time or any applicable sales tax. I would advise you to have the car looked at by a trusted mechanic. With 115,000 miles on the odometer it can have some of these problems which are not severe. The money you spend to have it gone over by an expert will be money well spent.
I am planning to buy 2000 audi A4 with 95000 miles on it? What do I need to check on this car before I drive off the lot?
This info is from MSN autos.
Occasional problems on this vehicle, 4-cylinder engines only, are failures of the Engine, Engine Vacuum Hoses and the Mass Air Flow (MAF) Sensor. Failure of the Engine is caused because the engine oil gels. When proper maintenance schedules for oil changes are followed, oil gelling should not occur. Audi has issued an 8 year unlimited mileage goodwill repair for this condition. The cost to replace the MAF Sensor is estimated at $380.00 for parts and $60.00 for labor. The cost to repair the Engine Vacuum Hoses is estimated at $25.00 for parts and $65.00 for labor. The cost to repair the Engine is estimated at $4,775.00 for parts and $845.00 for labor. The cost to replace the Mass Air Flow Sensor is estimated at $500.00 for parts and $52.00 for labor. All prices are estimates based on $65.00 per flat rate hour and do not include diagnostic time or any applicable sales tax.
Occasional problems on this vehicle are failure of the Comfort Control Module, with 4-cylinder engines only, and failure of the 4-Way Hazard Flasher. The cost to repair the Comfort Control Module is estimated at $290.00 for parts and $65.00 for labor. The cost to replace the 4-Way Hazard Flasher is $31.50 for parts and $91.00 for labor. All prices are estimates based on $65.00 per flat rate hour and do not include diagnostic time or any applicable sales tax.
Top Lincoln Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
