Try to reinstall the driver here:
http://www.isonic.co.za/drivers.htm
are the sounddrivers on your computer installed..
It's not about installing the drivers. The trick is to install them correctly. The driver file provided only contains a bunch of files and no instructions on how to install the driver. Isonic also does not provide any advice or instructions on their site. After weeks of trying, I have decided the best thing is to trash the card and to stay away from Isonic products forever.
It sounds like there might be an issue with the drivers or settings for your TV card's audio device. Here are a few steps you can try to troubleshoot the problem:
1. **Check Connections:** Ensure that all cables are securely connected between your TV card
2. **Update Drivers:** Visit the manufacturer's website for your TV card and download the latest
3. **Check Volume Settings:** Make sure that the volume is not muted or set too low on your computer and on the TV card's software settings.
4. **Test with Different Software:** Try using different soIt sounds like there might be an issue with the drivers or settings.
Lost cd
hope this helps
