Question about DISH Network Televison & Video
Dish Network VIP 722K DVR error Code message 207
Its been working fine for the past two years, even with our services shut off I can still get DTV signals via the modulator and am able to watch my DVRED programs from both the internal and external hard drives. Just this evening its giving me an error message code 207 services not available when I press the pause button and any buttons that work with the DVR. Even the DVR button to access the hard drives is showing the same message, I would like to be able to finish catching up on my recorded shows.
Posted by Tom A Funke on
  • Tom A Funke
    Tom A Funke Mar 14, 2015
    Called Dish Network today and I have my answer as to what error code 207 is since it was on all three of our VIP 722K DVRS. Basically after a certain ammount of account inactivity they will shut off the DVR features.
Will
    Habit-Forming:
  • 91 Answers
Call Dish and check if your service is active, then have them send a programming authorization hit to your 722.
Posted on Mar 27, 2020
5 Related Answers
Jim Franks
  • 374 Answers
SOURCE: Dish VIP 612 breaks up when playing back recorded shows.
Edy, I am not going to say that this is the definite issue but Dish only has receivers that are 1080i compatible at the time which will give you some blurring and possible pixellating. 1080p will resolve these issues in the future. Therefore if you still need help let me know.
Posted on Mar 03, 2009
Jim Franks
  • 374 Answers
SOURCE: Want to copy shows recorded to DVR onto computer Howto...
ArmyMason,
Unfortunately as a Dish Network Employee I must inform you that acording to Dish that is not possible however a good computer tech may be able to help you with a work around but keep in mind that if any damage occurs to the receiver that Dish will charge you for the receiver. When you do upgrade check into the receiver models that have an expansion port for an external hard drive. A 211 which is a solo hidefinition receiver without DVR can have a port activated for as one time charge of 39.99 and you can use the hard drive you supply as the DVR. Yoiu also will not be accessed the 5.98 DVR fee every month and if the receiver needs replacing you still have your recordings. Thanks for using Fix Ya.
Posted on Apr 10, 2009
SOURCE: Dish 625 DVR recorder won't play recorded shows.
Hi I will be more than glad to assist you in this concern. First press the power button on the front panel of the receiver for 10secs. once you press it the receiver will turn off and it should turn on by itself, once it turns on by itself you will see attention 015, press the menu button on the upper left of the remote, once you see the menu button press 6, 1, 1 on the remote and it should show on the screen point dish, select on check switch, once u are on the installation summary screen, select on test and it should do a test of 1 of 3 or it depends on your sat orbital location that u have.. once its done, it will show the installation summary screen and you should see sat input 1 & 2 with port1 up to 2 or 3 depends on your sat orbital location, all the trans on the sat 119, 110 or 129 if you have should be ok and green. once you see that all ok, select done on the screen, and it will be back to point dish, select done again, and then cancel all the way out of the menu, it should show on the screen attention 015, let it finish until it download the programming guide, once its done it should show a tv pic. press the dvr button and access your recorded event, it should play the dvr event. if the problem still exist, unplug the power of the dvr from the power outlet for 1 minunte then plug it back again and it should acquire the sat signal and download the programming guide, once it shows a pic. press again the dvr button and access the recorded event. it should play the recorded event, just incase the problem still exist, check what will be the exact error msg, write it down in a piece of paper and please feel free to get in touch or you can call on 1-800-333-3474..in order to for the dish tech support replace the receiver, this is a dvr lost of function.
Posted on Sep 05, 2009
Jim Franks
  • 374 Answers
SOURCE: Dvr not working. Won't record, pause rewind
Try unplugging the unit from the electrical outlet for about five minutes- much longer than required- and try it again. If this fails you will need a service technician to resolve the issue. Thanks for using Fix Ya.
Posted on Sep 28, 2009
Matt Gonzales
  • 25 Answers
SOURCE: Will not record a program, can not access dvr
Hello this is Matthew Gonzales with DISH Network customer service. With a 024 message, the best thing that we can do is hard reset the receiver. To do a hard reset, you simply unplug the receiver from the power outlet it is connected to, leave it unplugged for 20 seconds, then plug it back in. The receiver reboot process takes about 5 minutes. Once the show is back on, try accessing your DVR again, if it is still not working, the receiver will need to be replaced. If this is still a problem, please feel free to email me at [email protected] with your account number so we can get this resolved.
Posted on Dec 23, 2010
Toshiba 20AF42 is the tuner Digital or Analog? Chassis M3K62
This tv is a Analoge tv.Only can be able to used with CABLE,SATALITES or some other pay tv services to able to get a picture.Can't used the alone trying to recieving the DTV free AIR signal,will not work.Only way to get free AIR DTV to work for this tv is.This tv must have a Digital Coverter box hook up.The free AIR broadcasting signal must go through the tv Digital Converter box to be able to watch Free AIR DTV channels broadcasting.
Sep 04, 2011 | Toshiba 20a43 20" TV
I have been following instructions to convert my Polaroid to digital (via Menu; configuaration; add channels (auto) and tried new channels (auto) but keeps failing. The equipment I purchased from...
Hi, I have had the same problem with DTV. Unfortunately most of the time you need to buy set top DTV antennae to receive even a few channels. I recommend the expensive one that repositions itself for each channel ( DTV will not tune in a weak channel-it may show one from time to time after initial signal is locke in, may be a little scrambled looking for a moment or garbled speech) otherwise your stuck acquiring channels one at a time after repositioning the antenna each time.I'm sorry I didn't have better news but I hope this helps, comment let us know how we did, and good luck,Prodzilla
Apr 13, 2011 | Polaroid Televison & Video
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
My DCT6200 cable box keeps shutting itself off and then turning back on. I have already tried resetting it by unplugging, but that has done nothing. Even after I have turned off the power and left it...
1) have you tried changing that box in that room to another and the box from the other to this room. That may give you an idea of either power or signal strength issue.
2) after it resets does a "dl" show up on the box front. if so it is trying to download a firmware/software update and everythime you power cycle it starts over.
3) turn the box off then hit select and go to option 8. there should be 4 modules enabled.
4) you may need a new box
Aug 02, 2010 | Arris DCT6200 DTV Receiver
DTV signal will not come up on start up but after warm up
Was just the DTV card replaced only or the mainboard? Replacing the entire mainboard should do the trick.
May 22, 2009 | Vizio L32 32 in. LCD HDTV
My dtv keep saying nosignal antina hooked up .protron tv was working fine ran scan station. stop playing
dtv needs a strong signal to keep track of the channel. The antenna is good inside the room but tends to be affected for interferences. to catch signal (as in the past with ear rabbit antena) is difficult inside the room. and roof antenna is better but needs a good installation. the cable channels can work digital without the dtv. Is hard to give you any idea besides this ones because i don't know how the set up[ is in your case problem, but i hope i could help you a little. Now if the antenna is rasonable good and still having problems with your channels the suspect the dtv failure.
Apr 24, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
Light
My watch had the same problem and i could never figure out what it was so i just lived with it for a couple of years. then, just recently even when my watch was getting plenty of sun the battery would die in the evening and shut off at night. so i replaced the battery and evrything works great. even the light which leads me to believe the solar panel is just a gimmick. i have an old g-shock watch that i bought in 1989 and it still works and is on the origional battery. my gw 300 is about 5 years old and needed a battery. i guess 5 years on a battery is prety good but i would rather have it last for 19 years like my old one.
Jan 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Cooktop's electronic igniter started clicking all by itself
Check to make sure your burner caps are aligned. I had this problem, and it turned out one of my burner caps was slightly askew. Putting it level fixed the problem.
Jul 25, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Televison & Video Logo
413 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
