Question about Canon PIXMA MP495 InkJet Printer
Refilled Cartridge installed, but error U051 appeared and will not proceed to print
5 Related Answers
Anonymous
  • 81 Answers
SOURCE: I am trying to reset
Hi, did you refill yourself or did you buy a refilled cartridge. If you purchased a refilled cartridge and the chip is missing, you will need to take the chip off your old cartridge and install on the refilled cartridge.
Posted on Jun 22, 2008
Anonymous
  • 24 Answers
SOURCE: u051 install the print head error reading, do I
the printhead it is attached at each cartridge, so, there are two options: a) cartridge damageds or b) bad read cartridge contacts.
Do this, take out the cartridges, check if the contacts are clean and dry, then be sure to fix well again in the printer, if an error message appears, push the cancel button by 6 seconds, this deactivate the ink level sensor.If the error stay, 6 seconds 1 more time, if not works, I think that one or both cartridges are damaged, try with a new pair.
Posted on Jul 25, 2009
canontech
Canon tech CROATIA
  • 1219 Answers
SOURCE: ERROR MESSAGE U051
Print head not installed,
or not properly
installed.
[1401] U051 Print head is not installed. Install
the print head.
Install the print head properly.
It may be that print head is defective or main PCB assy
Posted on Jan 12, 2010
Anonymous
SOURCE: Error on my printer - Ink Cartridge not properly installed ...
We are a printer consumables manufacturer in China mainland,
We make compatible cartridges,refillable cartridges ,continuous ink system,for use with Epson,HP,Canon,Brother,and Lexmark.
We ensure our quality can match to the OEM products,and the price much lower.
Should you feel any interest,welcome to contact me at e-mail: [email protected]
Thank you.
Mike Zheng
Dongguan Ocbestjet Printers Consumables Co.,Ltd
Web: www.ocbestjet.com/en
Posted on Mar 13, 2010
F1xer
Fixer
  • 415 Answers
SOURCE: My Canon Pixma MP220 is has an error code U051 Chk
Using refilled ink cartridges will get this error. You have to reset the waste ink levels by doing the followin
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. hold the Power button, release Resume Button.
  4. Without releasing the Power Button, double click “Resume” button and then release Both Buttons.
  5. Click “Resume” for four times then click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Posted on Aug 12, 2010
Inserted refilled black cartridge and get U051 code saying printer head not installed ???
Hi, the error needs for the print head to be reinstalled. After doing this you must do a print head alignment from the maintenance screen on the printer. Hope this helps. All the best.
Mar 13, 2015 | Canon MP490 InkJet Printer
How to make Canon pixma MP-220 to recognise refilled ink.
Read the manual.
Get online and got to www.google.com In the google search box type: "Canon Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for manuals on the site.
An Error Message Is Displayed on the LCD (MP220 series)
Message
Action
CHECK INK
U051/U052/U053/U059
The FINE Cartridge may not be installed properly, or the Cartridge may not be compatible with this machine. Open the Scanning Unit (Printer Cover) and install the appropriate FINE Cartridge.
If the error is not resolved, the FINE Cartridge may be damaged. Contact your Canon Service representative.
Jun 02, 2012 | Office Equipment & Supplies
My Canon MX310 has an error code U051. I have tried 3 solutions on fixya and they did not work. One solution I get to this step and my printer will not show a steady alarm light.\r\nthe step that won't...
Error Message: Check Ink U051
This message appears when the cartridge not installed, not properly installed, or non supported cartridge is installed.
As a result the printer cannot recognized the installed cartridge.
Remedial action:
* Reinstall the cartridge properly
* Ensure that you installed supported cartridge only
* Replace the cartridge
Nov 18, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 error message U051 check ink
This will clear your printer from displaying common printer errors like U053, U051 and U052. The importance of the "reset the cartridge" procedure is to avoid the printer from detecting your cartridge as reused one. The steps below is recommended to do after refilling an ink cartridge.
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
What happened when ink ran out from a refilled cartridge and the printer detected it?
The printer will display an error U162 or U163. All functions of the all-in-one printer will stop and your printer will not work. The next thing you will know is you are in the front of a computer shop and buy a genuine canon cartridge.
But wait, there is still a way to fix this. Reset it again using a different procedure. Reset the detections of reusable cartridge.
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
Let me know if this works with you
Please rate this solution. Thanks
Aug 02, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon Mx 300 Printer wont work
Error Code [1401] or CHECK INK U051 = cartridge may not install properly or using non-genuine cartridges, refilled cartridges or faulty cartridges.
May 27, 2010 | Canon MX300 Office All-In-One Printer
On my canon MX 310 printer I put in new Canon CL-41 Fine color cartridge and now the alarm light is lit and the screen says Check Ink U051 COL How can I correcty the problem?
You may need a new cartridge, that error says the ink cartridge is wrong or not installed properly. If it's a refilled cartridge it won't work, if it's a new canon cartridge, they warranty for 30 days from date of purchase.
Dec 23, 2009 | Canon PIXMA MX310 All-In-One Printer
U051 install the print head error reading, do I need to change the cartridges, or the print head
Jul 14, 2009 | Canon PIXMA MP470 All-in-One Printer
Error message U051 on canon MP460
Check the Label on the cartridge if it covers a certain area then you will get an error message. Compare it with a good cartridge the label should nearly touch the lugs at top end. Only applies to refilled Carts.
Oct 04, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Printer error on a canon mp 470
How I can fix the U051 problem with my conno : MP470 printer ? It says the print head is not installed. Install the print head. Where is the it , and how I can fix it?
please e-mail to [email protected]
Jul 26, 2008 | Canon PIXMA MP470 All-in-One Printer
Canon PIXMA MP495 InkJet Printer Logo
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
