2004 Chevrolet Silverado Logo
Sarah Freebourn Posted on Jul 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Grinding/Low Whining noise when turning
It's most noticable when trying to park, but my '99 Silverado is making the worst whiny grinding noise when turning left to right. Power steering fluid is full, and there are no kinks in the line. I'm leaning towards wheel bearings, but at $130 a pop, I'd like to be sure before randomly replacing things.
When accelerating into a turn, the noise is non-existant, but from a stop, or while trying to park, it's so loud that it's embarrassing! Any suggestions? Thanks!
Anonymous
Level 3:
  • Master 322 Answers
  • Posted on Jul 09, 2009
Anonymous
Master
Level 3:
Answers
322
Questions
Helped
133525
Points
1059
Sounds like the power sterring pump check valve is failing because it only when you turn, try to turn the wheels standing still to verify the noise, if noise present, replace the ps pump.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 22, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1732
Points
Why does my 2004 Chevy Tahoe make a rattling wire sound every morning when I start it? When I take off it cont'ds the rattling wire sound like if there were cans underneath can anybody help me PLEASE?
Anonymous
Level 1:
  • Posted on Sep 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1732
Points
Sf1129, I have the same noise going on with my '04 Suburban -- have you had any luck in resolving the issue? Thanks!
Josue Almodovar
Level 3:
  • Master 298 Answers
Josue Almodovar
Master
Level 3:
Answers
298
Questions
0
Helped
156288
Points
1047
By lifting the wheel and turning it you can feel if the bearing are shoot you can hear the grinding noise
1helpful
2answers
Signs of awheel bearing going on a daf cf85 430 articulated lorry 2004 ?
Wheel initally with start making a washing machine noise or grinding sound when doing sharp turns the opposite of the wheel side as the outer race will generally go bad first. You may also notice the rim heating up due to friction. Grinding at low speed or a growling sound would dictate an inspection.
2answers
Whining noise when going 15 mph or less
when your brake pads get worn out they will make a slight grinding noise and when you depress your brakes they will go away .p[retty soon they will grind when you press on brakes.
I have a 1993 Mazda Protege it makes a whining noise on the left side as you accelerate it gets worst, seems to go away as car is warmed up
check all fluids, p/s,& trans ....this sound sometimes is ***. with the trans (worse case ) or is ***. with the wheel bearings but normally is a rough grinding whining sound
Im getting like a grinding thumping noise up front of my 2004 Silverado. The grinding is louder when I go into my 4x4. It seems to be the worst when Im turning slightly left. It started out making the...
My 2004 Silverado is displaying a similar issue - but it grinds loudly on either a sharp left or right turn at slow speed - it feels like it is winding itself up terribly then releasing that energy in burst as it skips & hops along. If you shut the truck off in this position, then try to restart it, it will lurch forward a good foot as soon as you turn the key. I have no idea what the problem is
1helpful
Car makes a metal grinding noise at idle
sew them. something is stuck did you turn or anything in the wash?
Steering Proble,
check power steering fluid .if really low check for leaking hoses.
1helpful
2answers
Grinding noise in the left front wheel while turning right - gets more noticeable the harder the turn is. Checked tire clearance - no problem, but it's not a rubbing noise but a grinding noise. No problem...
grinding on front wheel is caused by 2 things. a bad or loose wheel bearing,or worn out brakes, have them both checked
You might also want to check the level of fluid in the power steering reservoir - low or lack of fluid will also cause a noise (although more of a whining than a grinding).
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
